RV.Net Open Roads Forum: Tech Issues: Basics of Lithium conversion... I'm lost!
 > Basics of Lithium conversion... I'm lost!
Page of 9
C Schomer
Pueblo West, Co.
Posted: 04/20/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I did a search and it's mostly Greek... to me. I'd like to know the key points for, hopefully, a straight across lead/acid to lithium conversion.
My old Flow-Rite watering system just overflowed 2 cells (GRRRR) and I'm thinking this might be the time to convert.
So far I see that SiO2 is better than Li but I don't know why or what the difference is, and charging is much simpler for lithium and not so fussy.
I currently have 2 of the bigger Sams 6gc's that have dimensions and specs similar to T-105s, 2 X 120 watt panels and a Morning Star controller with remote panel/setpoint, that the PO installed.
I don't use an inverter for any 120ac loads. I'm nearly always plugged in to 120. I have no big 12vdc loads... my 5er has full LED lighting but I use a 12vdc bipap for very rare boondocking. The biggest addition might be a 12vdc fridge, someday.
Is there 6v and 12v lithium batteries? I seldom need the capacity I have now but I don't want to give it up, for the times I need the 12vdc bipap. Can I get similar capacity with lithiums and also fit the 2 x 6gc foot print? How much capacity to run a 12vdc fridge? Do I need a different solar controller or just reprogram my existing one? Thanks bunches! Craig
2012 Dodge dually diesel. CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
LouLawrence
Traveling the US!
Posted: 04/20/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Don't change. You are welcome! If you want to upgrade an AGM will solve any watering issues. LIthium $$$$$$$$$$$$$$$$$$$$$$$$. AGM only $$$$$. Install AGM and never look at your batteries again for 5-10 years.
Monterey, California
Lithium batteries when you seldom dry camp seems unnecessary and expensive to me.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
C Schomer
Pueblo West, Co.
Posted: 04/20/21 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Nice... that's simple! I just looked and my Duracells are EGC2 and 75 amps/120 min. per battery. Now that I think about it... I've used "starting" AGM's in a previous truck. Isn't that the red and yellow tops? I think one mfgr went to China and there was one that stayed here. Do you know the mfgr that stayed here? I'll start shopping. Craig
pianotuna
Regina, SK, Canada
Posted: 04/20/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
In my opinion Li are the fussy. I'm sure the lithiumites may disagree.
Since you mainly plug into shore power and no inverter is in use, I would recommend any sealed battery. Your choices are Gel, AGM, Sealed lead acid, or if you have deep pockets SiO2.
Regards, Don
FWC
The Wilderness
Posted: 04/20/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you use the camper a lot, and plan on keeping it for a while, then lithium may make sense as the $/A ends up being much lower over the life of the battery. But if you are mostly plugged in and only use the camper occasionally, you may never see the pay off from lithium. SiO2 is the worst of both worlds, costing much more than AGM, without the benefits of lithium.
BFL13
Victoria, BC
Posted: 04/20/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Apparently all you have is some broken (badly looked after?) batts. On shore power mostly, all you need is a single 12v FLA, if that. converter can do it all. No need to jump to expensive batts to solve this.
SiO2 are not "better" than LFP, and LFP is not "better" than SiO2. AGMs are not "better" than FLA or VV either.
You just need to sort out what went wrong with the batts you have and don't do that again with new ones, if that battery bank is ok for your scenario.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
theoldwizard1
SE MI
Posted: 04/20/21 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
I don't want to start an argument, I am just curious why you would say this ?
pianotuna
Regina, SK, Canada
Posted: 04/21/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
thewoldwizard1,
Li have many good attributes. But they are a maze. For best life span take no lower than 40% state of charge, do not charge to more than 90%, do not float charge, store at 50% state of charge, do not charge below -4 f, have a dc to DC charger to protect the alternator, have a good battery management system, do not use above 140 f (irrc), do not draw power at greater than 0.5 C (not for all makes), have a high voltage (14.8 volts) source available to "reset" the battery management system if it "shuts down" the battery, Charge to 100% to rebalance the cells every so often, do not discharge to 0 soc, do not use temperature compensation charging, do not wire in series and initial cost is quite ridiculous unless you roll your own. I'm sure there are items I missed. I think that qualifies my statement that they are fussy.
Because each time I mention, or some one else mentions the many requirements for ideal cycle life in Li, that person is subjected to disbelief.
I should add, Li can be a great bank to own, and may offer excellent service.
* This post was edited 04/21/21 09:17pm by pianotuna *
3 tons
NV.
Posted: 04/21/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Per PT: “ In my opinion Li are the fussy. I'm sure the lithiumites may disagree.”
Ha, it’s not that LFP’s are fussy, it’s just that ‘they’re (*) different’ (than old lead tech...), so it’s in this way that the Lithiumites happily part ways with the whip and buggy Luddites - [emoticon]
https://en.wikipedia.org/wiki/Luddite
* Note, For those tired of shoveling, Lithium can be uber liberating in this way - lol
3 tons, in the High Desert where ‘Lithium and Solar Harvest’ go together like Love and marriage...
Page of 9
