RV.Net Open Roads Forum: Truck Campers: Are lithium batteries worth the cost?
 > Are lithium batteries worth the cost?
Page of 8
BFL13
Victoria, BC
Posted: 04/28/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Durb wrote:
I installed a 100AH Battle Born battery and Progressive Dynamics Lithium Convertor in my trailer. No maintenance, no removing the battery during the winter, no battery tender during the off season. I don't obsess about SOC and all the other stuff in this thread. I just ignore the battery and expect to do so for the next ten years. So far, the battery meets all my needs. So, for me, the lithium conversion was worth it.
If that means you are leaving it plugged in for long periods of time doing 14.4-14.6 after it has been fully charged, AFAIK, that would be against Battle Born's guidelines.
Some say to isolate that PD Li converter from the LFPs soon after the batts are fully charged. You still want the converter on in the RV.
That PD Li converter might have been a big mistake in their rush to have something to sell with "Li" written on it.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
FWC
The Wilderness
Posted: 04/28/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, I have no idea why progressive dynamics thought a constant 14.6V output would be a good fit for a lithium battery. You want to shut this off after the battery is charged, or better yet just use their regular converter, which is better suited to lithium.
jaycocreek
Idaho
Posted: 04/28/21 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Battleborn wrote:
If you are storing your rv and wish to have it plugged in, we would recommend a float voltage of 13.6 volts. If you have a higher voltage applied in float(such as 14.6) then we would recommend that this be no longer than 3 weeks at a time.
time2roll
Posted: 04/28/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I would far prefer 14.3 with short absorption and drop to 13.3 volts for immediate storage or continuous normal use. Holding LFP at 100% is again applying lead-acid charging parameters to a different battery. Change is hard.
675w Solar pictures back up
Durb
NW
Posted: 04/28/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Let me get this straight. Progressive Dynamics, a leader, designed a convertor for lithium batteries that isn't as good for lithium batteries as their non lithium convertor? What if I just unplug the convertor between trips, say three weeks? I do disconnect the battery during the off season. I wonder why Battle Born sells my exact charger for use with their batteries.
FWC
The Wilderness
Posted: 04/28/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
That is correct. It is not going to destroy your battery, but at minimum I wouldn't leave it on while you are not actively using the camper. LiFePO4 batteries don't need to be float charged at all, and certainly don't want to be float charged at the very top of their voltage range.
Being a 'leader' an industry that is not exactly known for its technical prowess doesn't count for much.
StirCrazy
Kamloops, BC, Canada
Posted: 04/28/21 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Dodgemahal wrote:
StirCrazy wrote:
Dodgemahal wrote:
Not putting a DC to DC charger in the system carries the risk of two things. Discharged lithiums can pull max current from your (non smart) alternator which will burn it up and possibly cause a fire. Ending up on the side of the road is a big possibility.
Lets clear this one up before it starts spreading as fact.
The only way this is going to happen is is some one took the fuse out of your charging line for your 7 way. Or if some person who didnt have a clue installed there own because it want a factory option and didnt put a fuse in.
I think most of this stems from the youtub video of a guy hooking a li pack directly to an altnator with large wires and started it up using an electric motor. no fuse now voltage loss and yes it did start stuf burning.
having said that I still would encourage the use of a LFP compatable DC to DC charger and proper wiring to provide the LFP battery its best charging.
Steve
Steve
Well you just reiterated what I was mentioning. The proper way to charge Lithiums (with the truck charging system)is with a DC to DC charger and not unregulated with a smart or dumb alternator. Because the lithium battery will absorb a lot of amps if you offer it up. Not sure what you cleared up though. Facts are what we both stated. So thank you. [emoticon]
what I cleared up is that in reality if you have LFP batteries hooked to your charging system you will most likely be fine. the smaller fused charging line will only let so much go and it wont be enough to blow your altanator, and most likely not even enough to pop the fuse. is a DC to DC better, ya I would recomend them no matter what type of battery you have as a truck altanator throws out what it throws out... designed for a starting battery but it isnt dialed in for deep cycle, agm or LFP. it will work as the values are close enough but not optimal.
so realy unless your factory vehicle has been messed with you have no worries while you are waiting for a proper charger to install.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
otrfun
On The Road
Posted: 04/28/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, Battleborn may "recommend" the Progressive Dynamic single-stage 14.6v Lithium charger, but they qualified that recommendation when I called them a year ago. They "suggested" the PD Lithium single-stage 14.6v converter/charger not be connected to their battery for more than 2 weeks *if* it wasn't being used/discharged during that time. In other words, don't float the BB with this particular converter/charger for more than 2 weeks.
BTW, PD is fully aware of BB's position on this. They told me a year ago they were working on releasing a 2 stage lithium converter/charger line that would float at 13.6-13.8v.
time2roll
Posted: 04/28/21 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard the PD two voltage lithium converter is already out. Still too high IMO.
FWC
The Wilderness
Posted: 04/28/21 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe third time will be a charm for Progressive Dynamics?
Page of 8
