RV.Net Open Roads Forum: Tech Issues: 50 amp RV outlet
 > 50 amp RV outlet
grizz272
frozen tundra, WI
Posted: 04/22/21 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I have the four wires. Right now the neutral and ground are connected together.
I will check to make sure the neutral is connected correctly in the circuit box though.
Cummins12V98
on the road
Posted: 04/22/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Are the Red, black and White 6ga? Green can be 6 or 8ga.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ScottG
Bothell Wa.
Posted: 04/22/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Neutral and ground should only be connected together at the main panel.
grizz272
frozen tundra, WI
Posted: 04/22/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure of the wire size.
You are right that the white and ground should not be connected but that is how they connected a 3 prong outlet to a 4 wire cable.
time2roll
Posted: 04/22/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Put a wire nut on the neutral to keep it isolated from ground.
Ground-Neutral bond should only be made at the main panel.
Of course if you swap on a NEMA 14-50 the neutral will be connected but not to the ground.
675w Solar pictures back up
Bobbo
Wherever I park
Posted: 04/22/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I may be wrong, but I think the GROUND wire (bare or green) can even be 10g, per the NEC. Of course, local codes may differ.
Bobbo and Lin
grizz272
frozen tundra, WI
Posted: 04/22/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
NEMA 14-50 has been ordered. Now to find some wire. I try and buy local when I can. Nobody had 50 amp rv outlet. One hardware store had never even heard of it.
ScottG
Bothell Wa.
Posted: 04/22/21 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Home Depot has them - that's where I got the last one.
Or Amazon.
CharlesinGA
South of Atlanta, Georgia
Posted: 04/22/21 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Its a NEMA 14-50 which is a standard receptacle and plug for electric ranges. Home Depot and Lowes and Menards all day long. Asking for the "RV outlet" is where you went wrong.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
bucky
Raleigh metro
Posted: 04/23/21 04:44am Link  |  Quote  |  Print  |  Notify Moderator
So the receptacle and how it's wired is the difference between RV friendly 50 amp 2 leg 110 and whatever RVers plug into that fries all the ac things in their unit?
I have an electrician friend that did mine when we installed the whole house generator but I see a lot of do it yourself stuff done in the neighborhood without permits or inspections. Including a back feed outlet with no transfer switch on our house when we bought it.
Puma 30RKSS
 > 50 amp RV outlet
