RV.Net Open Roads Forum: Truck Campers: Fire Testing For Safest Foam Board Insulation
 > Fire Testing For Safest Foam Board Insulation
Camper_Jeff_&_Kelli
Seattle
Posted: 04/21/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
This is a continuation of my Dometic Fridge, Amish Built, Cooling Unit Replacement Topic. That project is finished and working awesome but! The question of Flammability of Foam Board Insulation Came Up. I decided to put my new RMAX by SIKA to the test against Pink, Blue, and the foam panel S&S included in the original build. I think this video will settle any argument as to which is the safest type foam board to use in a RV, TC, or Your Home. Enjoy!
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
jimh425
Western MT
Posted: 04/22/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Considering there are lots of items in an RV that burn much easier would it even matter if the foam was more fire resistant or not?
Kayteg1
California > Nevada
Posted: 04/22/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
With small space fire, few extra seconds for escape can be matter of life of death.
Camper_Jeff_&_Kelli
Seattle
Posted: 04/22/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
In this case, the insulation is next to a source of combustion. The fridge chimney is rated as needing 0 clearance. The chimney gets much hotter than touch. The old insulation paper was well browned. It is evident wherever a point of combustion occurs, the RMAX may self extinguish which is very advantageous.
Sjm9911
New Jersey
Posted: 04/22/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Everything burns or melts when it reaches a certain temp. You could use rotten cotton, rockwool or whatever its called by you for an insulation thats flame retardant to about 1000 degrees.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Sjm9911
New Jersey
Posted: 04/22/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, and have a working smoke and co detector in the camper.
Buzzcut1
Norcal
Posted: 04/22/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
if I was planning on sealing gaps in areas where I was worried about fire I would use a fire resistant expanding foam that is certified for just that purpose. There are many of them commercially available with ASTM certification
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Camper_Jeff_&_Kelli
Seattle
Posted: 04/22/21 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've used the Great Stuff Orange fire seal foam for a lot of penetrations for plumbing and electrical, also for framing fire blocking. Beware though, the fire block foam expands a lot and can have expansive force behind it that could be tricky to control in the thin wall space of truck camper walls.
Hemi Joel
Minnesota
Posted: 04/23/21 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Good stuff, Jeff. Thanks for posting this and the fridge improvements.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
