RV.Net Open Roads Forum: Fifth-Wheels: 5th Wheel entry steps
 > 5th Wheel entry steps
way2roll
Wilmington NC
Posted: 04/24/21 05:36am Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
"Besides all that we love them vs the fold outs."
I'm curious why you love them, when it appears they are a bit of a hassle in all but perfect conditions. I can see if a person were a bit unsteady on their feet, that a solid step may be nice, but just for normal usage, what is the advantage?
I did replace our old 3 step fold out steps with 4 step fold out and that was a huge improvement over the old steps. But that was because the steps ended too far from the ground and made that last step a lulu.
They don't just work in all but perfect conditions. In almost a year of ownership there was only one time it was an issue and that's when the guy parked too close to me in storage. I had so many problems with the electric steps on our previous MH's it seemed like they only wanted to work in perfect conditions.
Whiskey River
Pittsburgh, Pa
Posted: 04/24/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
OK, thanks all. At least I am not the only one that do not like these steps. The steps are somewhat sturdier than the fold under type, but that comes from the fact they reach ground, unlike the fold out type. I think the disadvantage far outweigh the advantages.
No one mentioned all the dirt, dust, sand & debris that gets dropped inside the rig when you lift the steps into the doorway. And yes you do have to sometimes adjust the length, shorten or lengthen, the steps to the lot, although this easy enough, just another thing to do.
I knew when I bought the rig I was not going to like them. I just thought I would put a rope on the steps and lift them into the rig, which I did a couple of times. Never thinking if someone pulled to close, I could not get out. One time I pulled into a rest area and tried to put the steps down and there was not enough room and not room for me to move over any more. That's when the "light" went off & I thought if I am inside with the steps up and someone pulls to close, I can' get out....
I now leave the steps out and put an orange cone beside the steps.
I know the nay sayers will say go to an RV park. I do that, except when I snowbird every winter. Not looking for hook ups ect, just a quick & easy 5/6 hours sleep and on the road again.
I've learned to live with these and will not change them out for only a couple times a year, just wondered what everyone else thought or did.
Thanks again......
BarneyS
S.E. Lower Michigan
Posted: 04/24/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
I have two versions of the Torklift Glowstep on my trailer - a three step version and a 4 step version. I found them to be very easy to use, solid with no bounce, and also good looking. Liked the first ones so much I got a 2nd set for the rear door. Our site slopes a bit so the the 4 step version was just right for it in the front.
They can be deployed no matter how close someone is next to you in a rest stop and everything is outside the trailer so no dirt is brought in when they are retracted.
Barney
Not towing now.
fj12ryder
Platte City, MO
Posted: 04/24/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Those are much nicer than the solid steps and seem to address the shortcomings of the solid steps, but I have trouble wrapping my head around the cost of those puppies. Way out of my price range.
Howard and Peggy
"Don't Panic"
goducks10
There
Posted: 04/24/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Our fold out steps are the ones with the metal side hinges and the aluminum steps. They're spongy and noisy. I've tried lubricating all the hinge points and it only lasts a few trips and they're noisy again.
Drop the solid steps down and they as they say "Solid" and silent. The trailer doesn't shake when walking on them. No squeaks. Those are our advantages over our fold outs.
YMMV
goducks10
There
Posted: 04/24/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again......
I have the 3 step version. Takes about 90 secs to broom them off. I keep a broom in my outside storage compartment.
If I got another one step only RV and it had the solid steps or noisy steps I'd break the bank and go with the Tork style. Since I have two fold outs it only made sense to go with the cheaper Solid steps.
GDS-3950BH
DC
Posted: 04/24/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
The RV Industry does not make changes for better performance, use or quality. They make changes only when the new design or item is cheaper to buy and install. These one piece fold down steps have to cost less in both materials and labor to manufacture, and labor to install. Notice they do not put windows in entry doors any more on lots of models? Another improvement.
jaycocamprs
Ringgold Georgia
Posted: 04/24/21 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Our problem with solid steps would be that they have to make ground contact. Where we park at home that's not possible.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Whiskey River
Pittsburgh, Pa
Posted: 04/24/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Barney:
Steps look good.
But I assume your rig came with fold down steps underneath from the factory. When you get the single piece steps that lift up into the door, there is no notch framed in under the door. So to put these in would require modifying the body & frame. Way above my pay grade...
Lynnmor
Red Lion
Posted: 04/24/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
That is my take on it. There is no frame and siding preparation, only a few quick zaps with a screw gun.
