RV.Net Open Roads Forum: Hybrid Travel Trailers: TravelStar 17CK
Open Roads Forum  >  Hybrid Travel Trailers
 > TravelStar 17CK
michaelw
Tucson
Posted: 04/22/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
I recently got a TravelStar 17CK, I am a complete noob to campers and RVing in general. I have a couple of questions that I hope the community can assist me with.
1. Disconnected Vent - in the area of where the battery is there is a vent line that is supposed to connect to something then be vented outside, unfortunately both ends of the hose is disconnected and I don't have any idea where it goes.
2. Just behind the Black/Gray water drain there is a hose protruding from the underside of the camper, is this used to flush the tank or does it have a different purpose?
Thanks for any assistance you may be able to provide, again a total noob here...
Thanks,
bgum
South Louisiana
Posted: 04/22/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Pictures would be most helpful. The hose near the drain line is likely a drain line for water heater or fresh water tank.
mdcamping
CT
Posted: 04/22/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
#1 I remember my past TT the battery was stored in an inclosed compartment in the camper, the battery it's self was in an water tight case with cover. The cover top had a flexible hose that connected to a external vent on the camper, maybe yours is similar?
(this was to vent battery fumes to the outside of the camper)
#2 my fresh water tank has a drain hose and a high point air vent hose for water to exit when filling
Mke
07 Toyota Tacoma,Double Cab, Max Towing 6,500lbs GCWR 11,100lbs
2011 Jayco X20E, Pro Series 800lb Weight Distributing Hitch
Husky Sway Bar, Prodigy Electronic Brake Control
McKesh Mirrors. "Towing with 210K"
Where we have camped
michaelw
Tucson
Posted: 04/26/21 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Photos as requested...[IMG]https://i.imgur.com/81tVvzCl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image. border="0" alt="[image]">
[IMG]https://i.imgur.com/jNry8DZl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image. border="0" alt="[image]">
bikendan
Camano Island, Wash.
Posted: 04/27/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the FW tank drain.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
 > TravelStar 17CK
