RV.Net Open Roads Forum: Tech Issues: missing cover
 > missing cover
swimmer_spe
Sudbury, Ontario, Canada
Posted: 04/22/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a cover that flew off of my trailer. It covered the opening for the propane fridge. Would it be possible to just make a frame out of wood, cover it with screening and it be safe?
enblethen
Moses Lake, WA
Posted: 04/22/21 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
A replacement cover would be easiest and possibly least expensive.
cover
Measure the length get screw hole dimensions. Several different sizes.
I am guessing you lost only the lid portion and not the complete assembly.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
lwbfl
Florida Panhandle
Posted: 04/22/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
The one on the side, yes but a replacement is probably pretty inexpensive.
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
Monterey, California
Posted: 04/22/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Wood may not last as long as a plastic cover.
swimmer_spe
Posted: 04/22/21 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
cover
Lid? It is on the side of the trailer.
swimmer_spe
Posted: 04/22/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
It is a 1999 Rockwood Ultra light 24 footer. If you can find one, that would be great!
enblethen
Moses Lake, WA
Posted: 04/22/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a Norcold version.
Refer access cover.
bob213
Fresno, CA
Posted: 04/22/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Was it the side vent. vent
or the one on the top?
BarneyS
S.E. Lower Michigan
Posted: 04/23/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
dougrainer
Carrolton, Texas
Posted: 04/23/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
1. 1999. There are only 2 access door makers. Dometic or Norcold. Both are available. There are different sizes so make sure you measure your existing hole. Also, a Norcold refer may have a Dometic side vent and Vice Versa.
2. DO NOT install ANY type screen on the side access door louvers. The purpose of the side door and louver cut outs are to get a certain volume of fresh air IN and up the back of the refer Cooling unit. ANY type screen material will block off about 50% of the volume of air needed to adequately operate the refer to cool correctly. Doug
 > missing cover
