RV.Net Open Roads Forum: Travel Trailers: Fast tongue jack
speediq99
Arizona
Posted: 04/23/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Any recommendation on a fast tongue jack for a 7500lb TT.
We just bought a new TT and the electric jack is extremely slow.
Thank you
MC
Monterey, California
Posted: 04/23/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I’m switching to a drill powered jack with a “emergency” arm powered handle option when this one gives up the ghost.
capacitor
California
Posted: 04/23/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Does your existing jack have a foot pad extension? If so, that and a piece of 4x6 will speed raising it.
QCMan
Independent Republic of Horry
Posted: 04/23/21 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Wow I never thought of getting a faster tongue jack! I could save at least 45 seconds each setting up and breaking down.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
goducks10
There
Posted: 04/23/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
I made a block out of PT 2"x 6" wood and use that under the tongue. I normally only have to lower the tongue a couple inches or so before it hits the block.
I'm guessing it's about 12"x 12"x 10.5" high.
I got tired of needing to stack wood when the jack was too far off the ground.
WayneAt63044
St. Louis, MO
Posted: 04/23/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Is it the speed of the jack or the distance you need to raise the tongue? If distance, consider the Fastway Flip Jack extension.
If speed of the jack, what's the make & model of the jack you have?
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
speediq99
Arizona
Posted: 04/23/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I will get back to you on the make and model.
It is a factory Jack that came with our Palomino trailer. It is painfully slow. I had an Atwood jack before and that thing moved.
I do have a 12 inch block to shorten the distance.
MC
ScottG
Bothell Wa.
Posted: 04/23/21 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I use one of these and it works great. Pull the lever and it folds up out of the way. Folding foot
JRscooby
Indepmo
Posted: 04/24/21 04:55am Link  |  Quote  |  Print  |  Notify Moderator
Just for S&G can you run jumper cables from battery to jack to see if it moves faster? If so you might want to run heavier wire and relays or heavy switches.
wanderingbob
monticeeo, fla
Posted: 04/24/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Put heavier wire ?
