RV.Net Open Roads Forum: Travel Trailers: Fast tongue jack
scottandgaye
Allen, TX
Posted: 04/24/21 07:03am Link  |  Quote  |  Print  |  Notify Moderator
QCMan wrote:
Wow I never thought of getting a faster tongue jack! I could save at least 45 seconds each setting up and breaking down.
It was a simple, straight forward question. It didn't require a rude response. To him, it takes too long. Without further information, you don't have any idea if your 45 seconds is accurate or not. If you can't be nice, then don't say anything is what I was taught.
2020 Ford F-350 LWB DRW PSD Platinum
2012 Hitchhiker Champagne 36LKRSB
LVJJJ
NW WASHINGTON
Posted: 04/24/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
our "new" Trail Cruiser had an electrc jack when we bought it. it was really slow. then the switch failed, altho if i took it out of its housing i could get to work. then one the side lights burned out. so i replaced it with an old manual jack i had sitting around. much better, and helps keep me in shape, I'm 75 and need the excercise.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
QCMan
Independent Republic of Horry
Posted: 04/24/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I was serious with that comment. My time is valuable. Maybe yours isn't.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Posted: 04/24/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Must be why you have 2 Jacks! (In your sig)
PS. Don’t be a tool...
2017 Heartland Torque T29
Posted: 04/24/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
wanderingbob wrote:
Put heavier wire ?
It’s a great suggestion. What’s the question?
Use your words...
speediq99
Arizona
Posted: 04/24/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
If you don't like the question, don't waste your time and everyone else's with an answer.
You made assumptions and that is always dangerous.
I've had a lot of electric jacks before. Most of them were not only fast, they were powerful. This one is a weak snail. Not only that when the base hits the support point, it slows down to a trickle. It is not 45 secs. This makes things time consuming hitching and unhitching with an Equilizer bar that tends to bind on the ball.
Stiffling conversations is not the best way to encourage people who are new to this is and frequent this forum. I have always gotten some really good ideas here. People are kind and helpful, not shameful.
We have all learned one way or another by reading and asking questions. At times, the most stupid questions get answered with stuff I've never heard of after camping for nearly 25 yrs.
No big deal, just skip to the next topic when you don't like it.
MC
philh
Belleville MI
Posted: 04/24/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
If the unit is operational, the odds are it's the model/mfg. There are some decent upgrades out there that even have hitch memory. Might be time to upgrade.
You could also get or make a jack lift.
goducks10
There
Posted: 04/24/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Baker VIP 3500 24" stroke. It's fast enough for me so I guess it's not real slow. I added one to a 2010 TT we had back then. We now have an 2019 ORV and they use the Baker VIP series. Super good customer service with Baker as well.
Back when I had my 2010 TT and a Baker VIP 3500 jack the switch broke past warranty. They sent me one for free.
JRscooby
Indepmo
Posted: 04/24/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I took this as tongue in cheek, certainly not something to get upset about.
I would of took it more serious if you had not said you could save the same amount of time set up/break down. Most use the jack more on break down.
OP, I don't know much about electric jacks, but many 12VDC motors in other applications (winch, tarp, 2 speed rearends, and many starters.) have run slow when extra resistance caused low voltage to the motor. And low voltage is a good way to kill a good motor.
mr_andyj
Georgia
Posted: 04/24/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
This is not an electric, but the part I am sharing is the "drop leg".
LINK HERE .
You can drop the leg to almost touch the ground then you can start the lift (electric or hand crank) without all the dead air space you currently have to move through.
You might need to have the mount welded on.
I am able to raise the foot off the ground just enough to remove the entire jack, so no wasted cranking.
I imagine a drop foot can be had for an electric too.
