RV.Net Open Roads Forum: Technology Corner: TPMS Question
 > TPMS Question
austinjenna
Columbus, Ohio
Posted: 04/23/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I recently installed a TPMS system and was wondering what the high limit is folks used as compared to what their PSI is. So my trailer tires are at 80 PSI and noticed they went up to 89 PSI on the way home. How much of a rise is there normally in tires so I know what to be able to set the high PSI alarm on?
Thanks
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
fj12ryder
Platte City, MO
Posted: 04/23/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
The rise will depend on the ambient temperature to a certain degree (HAR).
Personally I don't worry too much about high pressure, but probably 10-15% rise would be common. I would be more concerned with low pressure, and high temperatures. Those are better indicators of potential problems.
Howard and Peggy
"Don't Panic"
FWC
The Wilderness
Posted: 04/23/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
The rise in pressure is due to an increase in temperature. Much more than a 10% increase in pressure could indicate you have a problem with a sticking brake or wheel bearing, so setting the high alarm at 10 - 15% over the cool pressure would probably be wise.
ford truck guy
Pennsylvania
Posted: 04/23/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed the TST 507 series and they set it up for me... I run my tires at 115 psi... the low is set to 103 psi ( 10%) and the high is set to 144 ( 25% ) ..
They told me the standard was 10% for the low and 20-25% for the high setting
I just ran from PA to Richmond VA which was around 300 miles... 1st half was rain and mid 60's.. the psi was 120-122 psi... the 2nd half was sunny and mid 70's... the psi was 138-140... I am curious to see what they show when running in 100 degree heat down south......
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Near DVNP, California
Posted: 04/23/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Nine pound increase in an 80 psi tire is normal.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
CA Traveler
The Western States
Posted: 04/23/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Check your tire specs for the maximum pressure. TST indicates it should be about a 25% increase. I've seen 10% which does not include hot summer days on the MH.
I have both an internal sensors system (Smart Tire) and TST. The psi difference is 1 psi. The internal sensor temperatures range from 41 to 54 derees higher than the TST values. I attribute this to the TST sensors being mounted outside the tire on brass valve stems and rotating itn ambient air. In other words external sensors have significant lower temperatures than the actual tire temperature.
Stopping and quickly measuring the tire sidewall tempeatures resulted in values 6 to 26 degrees below the internal temperature.
2014 Grand Cherokee Overland
Bob
bob213
Fresno, CA
Posted: 04/23/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
What "ford truck guy" said x2
FWC
The Wilderness
Posted: 04/23/21 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
For reference, a 20% increase in pressure would be a ~60C (~100F) increase in temperature over ambient - that is getting really hot. If you saw that on your TPMS, you would want to pull over and check things out.
Bobbo
Wherever I park
Posted: 04/23/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I use 10% below to 20% above. For an 80psi tire, I would use 72psi as lower limit and 96psi for upper limit.
Bobbo and Lin
Beverley&Ken
Tottenham,Ontario
Posted: 04/23/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
As the others have said, TST recommends 10% below and 20% above. One hot summer, I got the over pressure alarm 104psi , high for the 80psi tire pressure was set for 96 but all tires were equally high, I reset the high for 105 psi.
Another note, one trip I used my infrared temp gun and found tire temps just over 150F. I checked the 18 wheeler beside me in the rest area and his temps were 175F/
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
 > TPMS Question
