RV.Net Open Roads Forum: Technology Corner: TPMS Question
 > TPMS Question
rlw999
Washington State
Posted: 04/23/21 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Check your tire specs for the maximum pressure. TST indicates it should be about a 25% increase.
The maximum pressure on the sidewall is the maximum *cold* pressure, so it doesn't really help determine the max pressure for warm tires.
austinjenna
Columbus, Ohio
Posted: 04/24/21 03:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I think I will set the high at 96 and take it from there. For the low I will set at 70
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
CA Traveler
The Western States
Posted: 04/24/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
OK The TST 507 manual states the pressure data charts plus about 25%. Hence the psi is based on the actual weight the tire is carrying after it is weighed plus 25% for the TPMS.
2014 Grand Cherokee Overland
Bob
 > TPMS Question
