RV.Net Open Roads Forum: LED Awning Light Strip Does not work on Brand New Trailer
 > LED Awning Light Strip Does not work on Brand New Trailer
jonaz
Posted: 04/24/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Just bought a brand new 2021 Coachman Catalina 263BHSCK. Upon PDI inspection, I noticed that the LED light strip would not come on (yes, I had the exterior light button in the on position). I cant believe my dealer did not have this fixed before I picked it up.
Anyway, I took the trailer home and there does not appear to be a fuse behind the control panel inside. I checked the connection on the right side of the awning where the LED light strip plugs into DC power by the awning and it was very lose (little 4 pin connection). One pin looked bent so I straightened it and plugged it back in. When I turn on the exterior lights now, the LED awning light strip flickers once briefly and turns back off. Any suggestions? Yes, the dealer can fix it but its going to take weeks before they can get me back in because I am having some other stuff done. Thanks in advance!
midnightsadie
ohio
Posted: 04/24/21 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
well youmust be close , I might by a new connector plug ,might hard wire it to make sure its the problem. some of those little connector plugs don,t get 100% put to gether right.
bgum
South Louisiana
Posted: 04/24/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I can't believe you took possession before it was fixed.
Fisherman
Angus, Ontario, Canada
Posted: 04/24/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
OK, had the same problem and found the solution, the light switch inside has to be on, but to make it work, you have to use the remote. You would think that the off/on switch would give you that option
JaxDad
Greater Toronto Area
Posted: 04/24/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
A friend had a similar issue, the LED’s were obviously installed by someone who doesn’t know they are polarity sensitive. I reversed the positive & negative and they worked just fine.
jonaz
Posted: 04/24/21 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to go camping and I figured it would be an easy fix.
[blue]2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears) Prodigy brake controller,Weight Distribution Hitch 2021 Coachman Catalina 263BHSCK
Note: Due to invalid formatting, all formatting has been ignored.
jonaz
Posted: 04/24/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about on the little 4 pin connector or this something else?
