RV.Net Open Roads Forum: Tech Issues: Problem with AGM Batteries
 > Problem with AGM Batteries
La Gasser
Louisiana
Posted: 04/24/21 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 Jayco Seismic Wave Toy Hauler with the original 2 Interstate AGM batteries which are now 4 1/2 years old. It seems that the batteries are not holding their charge as long when not plugged into shore power. I've had it off shore power for 1 day with the Battery Cutoff switch not on, meaning batteries are still connected. Volt Meter shows around 11 volts, but when you turn the Battery Cutoff switch on, the reading is 12.5 volt or approx 80%. If you activate the landing gear switch while the Battery Cutoff switch is on, the reading goes from the 12.5 down to around 10.7 volts. Seems to me that the batteries are just holding a surface charge when at rest, but when you put a load on them, they are shot. Does that seem right to y'all? Thanks
Ed_Gee
Central Oregon coast
Posted: 04/24/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds about right to me. You could try an equalize charge but probably won't do any good in my view.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
time2roll
Posted: 04/24/21 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Post the converter model number. Good chance they have been under charged. You really need to get these up to 14.4 volts.
Considering the low voltage it is probably best to separate the batteries for testing.
* This post was edited 04/24/21 11:56pm by time2roll *
675w Solar pictures back up
KD4UPL
Swoope, VA
Posted: 04/25/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Have you cleaned and tightened the connections?
I agree, if you have a factory converter it's probably not taking very good care of your batteries. I would separate them and test individually. One may be bad and the other okay. The problem with that is you don't want a new battery mixed with a 4 year old battery so you still would want to replace them both.
Bill/Diana
Southeastern Pennsylvania
Posted: 04/25/21 06:46am Link  |  Quote  |  Print  |  Notify Moderator
At 4 1/2 years old I would not be worried about meter readings. Time to replace the batteries with new and have peace of mind while camping. JMHO
Bill & Diana
Please click here to visit our Website
JimK-NY
NY
Posted: 04/25/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I have no knowledge of Interstate batteries but my Lifeline AGM batteries would typically last 7-10 years with reasonable care.
You have nothing to lose by trying a conditioning/equalization cycle. That is typically about 15.5 volts for 8 hours. If that doesn't fix the issue they are toast.
La Gasser
Louisiana
Posted: 04/25/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Converter is the factory Progressive Dynamics Model PD4590K 90amp unit. Connections have been maintained clean. When on shore power, meter shows in the 14.4 to 14.6 range initially, then reduces to the 13.2 to 13.4 range when charging so that appears ok. I also had Lifeline AGM batteries that were over 8 years old when I sold the previous trailer, so am disappointed with the life of these Interstate batteries, but it could be Jayco issue more than a battery issue. Will probably replace both with Duracell AGM's from Sam's Club. I've had good luck with their batteries in vehicles and my boat.
Posted: 04/25/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
the MYTH: AGM's last longer than properly maintained Flooded wet cells
The Truth: AGM's last longer than Flooded wet that are NOT maintained properly.
But the reviews compared to Well maintained are mixed.
I had two. independent 12 volt systems in my Rig for a period
one was AGM. they were the fastest to die
the other was a mix of Flooded wet and older Maintenance Free (Wet)
The AGM's were purchased and installed with the RV was around 11 months. at least one of the maintenance free was older than the RV and all of them outlasted the AGMs
Main (OEM interstate Flooded wet lasted 9 years.
Now I said reviews are mixed
Helped a man with a dead starting battery
His was a Die-Hard (Always died quickly for me) but his was an AGM 12 years old.
7-10 is average.
2oldman
NM
Posted: 04/25/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
My AGMs always self-discharged much slower than wets.
dougrainer
Carrolton, Texas
Posted: 04/25/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
As you probably know, Jayco did not install the Batteries. The selling dealer did. Jayco does not supply towable batteries. Now, AGM Interstate are good batteries. BUT, are you stating that a NO TIME in 4 1/2 years you never let the batteries go completely dead? Letting a AGM battery go dead, it will never return to its full capacity. Also, a LOT of Dealer's and Service Centers are ignorant of the conditions for installing AGM and now Lithium batteries. You need to make sure your RV charging system is capable of charging AGM's or Lithium correctly. Just get the manual for your Converter and it will state if it is correct for AGM's without a modification. Most Converter's are capable of charging AGM's correctly. Doug
