RV.Net Open Roads Forum: Tech Issues: A B Switch
 > A B Switch
hpdrver
Mansfield, Texas
Posted: 04/24/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have two coax inputs to use for my Dish Wally receiver. One input from roof top dish and the other input from outside portable dish. I am wanting to install an A-B switch to these two inputs to make it easier. However, I saw somewhere that since the Dish receiver sends power down the coax, an A-B switch is not recommended.
Does anyone use an A-B switch with a Dish receiver and does it work. What type switch is possible. Thanks
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
accsys
Green Cove Springs, FL
Posted: 04/25/21 04:57am Link  |  Quote  |  Print  |  Notify Moderator
We had a similar issue when we had a DirecTV SWM system and found that unplugging the receiver (in our case, including the SWM power supply) prior to making any A-B switch changes eliminated any problems. Yes, you have to wait for everything to boot up again but no big deal in the big scheme of things.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
LouLawrence
Traveling the US!
Posted: 04/25/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
If you use a high isolation A/B switch like this, you will be fine.
High isolation A/B switch
JimR 1
Custer South Dakota
Posted: 04/25/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I have a Pathway X2 on a Wally that goes through an A B Switch and I was getting a signal dropout. I changed from the switch to the Wally directly and no dropout.
But I could have a problem behind the switch so I will bypass the switch this week and connect to the coax that runs through the RV and test it out. My A B Switch is a factory install and is hidden behind a panel with just the A B buttons showing so I am not sure of what type it is.
This is a new install and I am still testing the system i.e. what works what does not how far can I run the coax ect ect.
JimR
Posted: 04/25/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
A/B switches come in two (times at least 2) flavors. for this post I will deal only with one of the two.
Mechanical switches: Work just fine with power to the dish in fact they have a slight advantage over no switch (Will describe)
Electronc (remote controlled) may or much more likely will not work with Power to the dish .
With the mechnical switch
3 Terminals A, B and C(Common)
C goes to the Receiver
A goes to the Roof up "A-Bove"
B to the portable connetion down B-elow.
(Makes it easier to remember)
To hook up outside dish.> First switch to A Thus removing power from the "B" connection Now hook up OPPS I accidently shorted it. NO problem because no power
once connected switch to "B" and aim the dish
Disconnect: First switch to "A" now again if you screw up and short. NO problem.
hpdrver
Mansfield, Texas
Posted: 04/25/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for info. Just ordered the high isolation switch and will follow guidance on how to switch between A and B.
Posted: 04/26/21 05:23am Link  |  Quote  |  Print  |  Notify Moderator
I mentioned 2 by several other 2's and more
HIGH Isolation v/s normal is another of the 2's.. High Isolation is best for most uses. Not sure it even matters for this. (Bit for sure it won't hurt)
JimR 1
Custer South Dakota
Posted: 04/29/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
This is an update to what I posted here a few days ago.
I bypassed the A B switch and my signal still drops out so there is something no good in the RV wiring.
My plan is to abandon the RV wiring and install new coax to the the Wally.
Just an FYI
PS I tested 150 feet of Coax and it worked
JimR
chuckbear
Posted: 04/30/21 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I use a similar A/B switch to do exactly what you want. But the first thing I did to eliminate any issues was to re-run new coax to bypass the original installed old coax. No problems in 4 years. Chuck
 > A B Switch
