cgjt
western new york
Looking at purchasing a tire pressure monitoring system for our travel trailer. Any suggestions regarding manufacturers and models would be appreciated. Leaning toward the Tymate brand but would appreciate suggestions. Thank you.
dodge guy
Bartlett IL
I like the TST system. Have it for my MH and toad. Works great and doesn’t drop out when you use the repeater (which is necessary).
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Wiscampsin
Wisconsin USA
We have the TST 507 and really like it. Link:https://tsttpms.com/
GTO66
Another vote for the TST 507 had mine for several years and its caught a few leaks which may have saved me a more serious problem.
Land Yachters
Philadelphia
Another TST vote. Bought system for MH and toad and works flawlessly. I had operator question about compatibility between the 2 valve sensors and called them. "Leave a message.."and **** if a very nice guy didn't call me back in 10 minutes and tell me to call anytime.
BTW, never needed booster. Picks up toad sensors everytime.
Land Yachters
Griff, Ali and Coco
Philadelphia, PA
2018 Tiffin 33AA
2018 Grand Cherokee
ford truck guy
Pennsylvania
Yet another TST 507 here.... It's my first one, and I really like it a lot
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
dieseltruckdriver
Black Hills of SD
I have no experience with anything but my current Tireminder, and I really am liking it.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Dick_B
Palos Heights, IL USA
Didn't read all the responses but I would suggest staying away from the sensors that are built into the tires because, at one time, not every tire shop could or would deal with the sensors when they repaired a tire. That may have changed but we have the kind where the sensor is installed on the metal valves so don't have the problem
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
the e-man
Virginia
I just bought the TST 507 with flow through valves. I tested it last weekend with good results. There are several good TPMS on the market. I liked the idea of the flow-through valves where you don't have to remove the monitors to add air. However, you'll need to have metal valve stems to use that model. On the trip, it cycled through each tire showing pressure and temperature. Seemed to work well.
I could use some ideas from the group on the best way to install the signal repeater. It looks like it could get attached on or near the battery box. But, it would be nice to have a shutoff to prevent draining the battery. How did you install it?
2018 Grand Design Transcend 28MKS
2010 Ram 2500
Travel Trail Sail - Info on Travel Planning, RV Camping, Outdoor Living
dodge guy
Bartlett IL
the e-man wrote: I just bought the TST 507 with flow through valves. I tested it last weekend with good results. There are several good TPMS on the market. I liked the idea of the flow-through valves where you don't have to remove the monitors to add air. However, you'll need to have metal valve stems to use that model. On the trip, it cycled through each tire showing pressure and temperature. Seemed to work well.
Mine is installed on the rear wall of my last storage compartment (class A). I just remove the fuse when it’s not in use.
