RV.Net Open Roads Forum: Class A Motorhomes: Inside sewer smell
 > Inside sewer smell
bob b
Grants Pass, Or
Posted: 04/25/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
My coach, a '06 Allergo Bus has begun to emit a sewer gas smell when flushing. I think that I need to replace those under-counter vents. What are they called and where to buy. Or, any other ideas? Thanks, Bob It's not the sinks as I stoppered and added water, no difference
bob b
Ranger Smith
Wherever the rig is parked
Posted: 04/25/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
You can purchase them at Lowes or Home Depot. They're about $8.00 each. They have them with a male and female thread so get the correct ones.
Where we are now
Amateur Radio Operator AA3SS . . . Yaesu FTDX 10D, Mercury III Amp, Icom 7100,Flex 6400M
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
CA Traveler
The Western States
Posted: 04/25/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Air admittance valve.
2014 Grand Cherokee Overland
Bob
ssthrd
Vancouver Island
Posted: 04/25/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
My wife calls them foo-foo valves...lol
Its called an Air Admittance Valve among other names. I would imagine that most RV or plumbing supply stores would have them.
Some screw on, others just slide on, so if you change yours, you might want to remove yours first.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Anderson
DeeBee, JayBee, and Jed the Black Lab
chuckftboy
Fleming Island, Florida
Posted: 04/25/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Commonly called "studor vents" by the commercial plumbers around here.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
phil-t
Ogdensburg, NY
Posted: 04/25/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Air Admittance Valve - Amazon
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
azdryheat
Tucson, AZ
Posted: 04/25/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
You could also empty your tank and give it a good flushing. Perhaps put in some toilet chemicals.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
gbopp
The Keystone State
Posted: 04/26/21 04:07am Link  |  Quote  |  Print  |  Notify Moderator
Don't buy the cheapest one you can find. Spend a little more and get a good one.
dougrainer
Carrolton, Texas
Posted: 04/26/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
1. The various air valves are connected to the GRAY system. So, flushing the toilet will not cause those valves to "leak" odors.
2. The most common sewer smell when flushing would be the rubber toilet seal on top the toilet flange.
3. Pour Pine sol in the gray tank and see if you get Pine Sol smell when flushing. This will narrow the cause down
4. IF you have a Clothes washer, make sure you have water in the washer P trap. Especially if you rarely use the Washer.
5. IF you are using Black Tank chemical(You SHOULD), then there should be no real smell coming from the Black tank.
6. Last, but I have seen this in Tiffins also, the 3 inch down pipe attached to the top of the Black tank from the toilet may have come loose or is NOT sealed and that will cause Black tank odor into the RV when flushing. The only way to check this is to pull the toilet, but if you need to check the toilet seal(item 2 above), then it is not a wasted effort. Doug
