RV.Net Open Roads Forum: Class A Motorhomes: Turbo goes out at 37,000 miles
 > Turbo goes out at 37,000 miles
lfeather
Titusville, FL
Posted: 05/02/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
It helps to lubricate the linkage at the turbo with some heat-tolerant oil too
Larry, Debbie & Max the Pug
USAF Retired
2014 Itasca Reyo P
2016 Subaru Forester 2.5i 6 speed manual transmission
Bikeboy57
Inverness, FL
Posted: 05/02/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
It may be too late for forensics. The answer to your question could be narrowed down from generalities if some quick inspections of the failed part were done. Were any of the blades broken? Which side, exhaust or intake? Did the shaft break? Were the bearings scored? Was the a actuator mechanism jammed?
Check your air filtration for holes.
Richard and Rhonda
1999 Newell
Subaru Outback toad
HHg in Austin
Austin, Texas
Posted: 05/02/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you are right about it being too late. I had talked with Cummins and they indicated a failure analysis could be done which would very likely provide the cause…..unfortunately Freightliner had already pulled it and sent it back as a “core exchange”. The actuator was bad and had to be replaced as well…..the Air Filter was replaced along with complete service on the engine and chassis. I’ve learned enough from this incident to make sure of what to do if there is a next time…..
HHg in Austin
2013 Tiffin Phaeton 40-QBH
2018 Chevrolet Tahoe Toad
