RV.Net Open Roads Forum: Quick connect LP fitting won't work with standard gas grill?
 > Quick connect LP fitting won't work with standard gas grill?
way2roll
Wilmington NC
Posted: 04/28/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
My FW has a quick connect LP fitting for attaching a grill etc. I have a nice grill and a camp chef LP fire pit. Both can be attached directly to a bottle. I thought I would try getting the quick connect hose that I could run either of these. According to my local RV shop, it can't be done. I was told that the quick connect fittings are low pressure and my grill and fire pit require high pressure and so there is no way to connect them. Is that right? Apparently there is a "special" grill that hooks to the quick connect?
MitchF150
Puyallup, WA
Posted: 04/28/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
You need to remove the regulators from the grill and firepit as the quick connect on the RV is being regulated by the rigs regulator. But, you will need to put them back on if you wish to use them with a stand alone propane cylinder.
Mitch
prichardson
Lafayette, La
Posted: 04/28/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
He is correct. Some grills can be converted with a kit that replaces the control assembly. Check with your grills manufacturer.
DancinCampers
Louisiana
Posted: 04/28/21 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I found a connector for my Blackstone grill on Amazon, with quick disconnect hose. Works great. I would chack if they have one for yours, if not amazon the google.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2006 Jeep Liberty, Blue Ox Aventa II, SMI Silent Partner
If You Obey All The Rules, You Miss All The Fun
agesilaus
North Florida
Posted: 04/28/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I looked, I found, this clicky
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
way2roll
Wilmington NC
Posted: 04/28/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
If I understand correctly (and that's giving more credit here than we should) I can take the current hose with regulator off the grill and/or fire pit, and attach this hose instead. Keeping the old hose of course and swap back if connecting directly to a small tank. Do I have that right?
bob213
Fresno, CA
Posted: 04/28/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Don't know what you have but you may find what you need here:
Torjik
Lantley
Ellicott City, Maryland
Posted: 04/28/21 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Yes that is the general idea.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Mel Stuplich
Wausau, WI
Posted: 04/28/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Most standard gas grills must be connected BEFORE the LP pressure regulator on the RV.
Cummins12V98
on the road
Posted: 04/28/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
