RV.Net Open Roads Forum: Quick connect LP fitting won't work with standard gas grill?
 > Quick connect LP fitting won't work with standard gas grill?
JimR 1
Custer South Dakota
Posted: 04/28/21 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Weber BBQ with it's own regulator and I use the low pressure side of the propane from the RV with the quick connect. Works just fine.
JimR
Posted: 04/29/21 04:03am Link  |  Quote  |  Print  |  Notify Moderator
Standard gas grill wants input to the regulator at about 100 PSI give or take quite a bit.
Quick connect is post regulator about 1/2 PSI. (NOTE the use the word about)
way2roll
Wilmington NC
Posted: 05/01/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I think I am just going to save my money and carry a small tank like I always have just for the grill and firepit. Makes me wonder though, since most of the grills out there require high pressure, why would manufacturers opt to put the quick connect after the regulator? Then you are either forced to buy a low pressure grill or spend a bunch of money to make it work with standard ones. Is it a liability to have a high pressure quick disconnect?
Lantley
Ellicott City, Maryland
Posted: 05/01/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Those quick connects were initially installed to be used with RVQ and RV specific grills. You need to adapt them to use with other grills.
Making the quick connect low pressure is ultimately safe and more cost effective vs. having high pressure running to each RV appliance and quick connect. One regulator controls the pressure vs. requiring a separate regulator for each appliance. You have to look at the big picture of the LP system vs. focusing on the quick connect.
I can attach all my lp appliance via quick connect or 20# tank. I have multiple hoses and connectors.
I don't mind carrying any extra tank. However I want to be able to spontaneously use my lp appliances even if I did not bring a spare tank.
I don't want to plan to use the appliances or remember to bring a tank.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
msmith1.wa
Tacoma, WA
Posted: 05/01/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Your grill will work fine with two low pressure regulators in the line. The pressure at the burner will be which ever regulator has the lowest pressure setting.
Depending on the fire pit it may not work as well as if it was connected to a tank using the regulator supplied by the manufacturer. Sum fire pits use a 5psi regulator, much higher pressure than than the regulator for the rv system.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
stickdog
Somewhere, USA
Posted: 05/03/21 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Mel Stuplich wrote:
Most standard gas grills must be connected BEFORE the LP pressure regulator on the RV.
You can't double regulate.
Remove the regulator from your grill and then connect to your standard regulated quick connect.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
msmith1.wa
Tacoma, WA
Posted: 05/03/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you can my dad did it a motorhome he had for many years.
Lantley
Posted: 05/03/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
A general rule of thumb is you can't double regulate.
I don't dispute that your dad was able to do it but for the most part to regulators will reduce the gas flow to inoperable levels.
JimR 1
Custer South Dakota
Posted: 05/03/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Mine work fine double regulating. My weber is connected to the low pressure side of the propane regulator using a quick connect, the Weber has a regulator too. All works well.
JimR
Cummins12V98
on the road
Posted: 05/03/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
I’m willing my to bet his BBQ worked but not at its full capacity.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
