RV.Net Open Roads Forum: Roads and Routes: EZ Pass with and without trailer
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > EZ Pass with and without trailer
philh
Belleville MI
Posted: 04/28/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Getting the EZ Pass device for east coast toll roads, do you need a separate unit for when you're towing vs not towing?
QCMan
Independent Republic of Horry
Posted: 04/28/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Nope! We have used EZ Pass with and without the trailer since 2004 and so far it has accurately charged us. The readers count axles after the pass and according to EZ Pass there is no need to register the trailer with them. We have had three different trailers and they got it right every time so far. Even the toll road outside of Charlotte NC got it right when we went through with the trailer one day and without it the next.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
WNYBob
Tonawanda, NY
Posted: 04/28/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I was told here in New York State by the Thruway Authority that I needed 3 EZ-pass tags. One for my truck, one for towing a single axle trailer and one for my truck and my 2 axel camper.
Several years ago was charged the highest toll rate for my truck with a truck camper, over $50 to travel from Buffalo to Albany!
There was no cost for the additional tags. I just have to remember to change them to match what I am driving.
Taxman2436
Holden, MA
Posted: 04/28/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
I’m in MA and was told the same thing WNYBob is saying. I have 2 EZ passes and need to switch between them for truck alone and truck and trailer.
Taxman2436
Holden,MA
2019 Ford F-250 6.7 L Diesel
2021 Salem Hemisphere
ford truck guy
Pennsylvania
Posted: 04/28/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^. same here in PA.... Thats why I got the one for a trailer to use and not a regular one.....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 04/28/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I can agree/disagree with all the comments.
EZ Pass website says you must have a different "tag" when towing a trailer.
EZ Pass Tag Order Form
After saying that, last fall I went to Rhode Island to pick up a couple tractors, towing a triple axle trailer. EZ Pass worked correctly in NY and Massachusetts using the transponder I always use with my truck alone.
Recently, I read somewhere (and of course I can't find it now) to tow a trailer you need to enter the number of axles and plate number of the trailer you are towing on the tow vehicle in your account.
* This post was edited 04/28/21 07:12pm by curt12914 *
2021 F-350 Platinum 4X4 PSD SRW 2016 Montana 3950FL (2) Honda EU2000i's
...and a few (twenty-some, but other than my wife, no one is counting) antique Allis Chalmers tractors
curt12914
Posted: 04/28/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking seriously of getting a
Uni-Pass to replace my EZ Pass. It is accepted in all states EZ Pass is, plus Georgia and Florida.
cgjt
western new york
Posted: 04/28/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
In NY I need two responders, a white one for the truck only. When towing my two axle trailer I need to switch the responder to the blue unit. The unit not being used is put into a protective sleeve in the glove box so the reader does not pick up the unit not being used and being charged for both.
Sjm9911
New Jersey
Posted: 04/28/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
In nj, they said only the one tag. It counts the axels. I have used it in ny and pa with no problems with 2 different axel campers.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
curt12914
Posted: 04/28/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
The biggest reason to get a different transponder in NY is that there is a discount for a motorhome, fifth wheel or boat. It is less expensive than a conventional trailer with the same number of axles.
Special Towing Discount
