RV.Net Open Roads Forum: Mobile Router that will auto connect to Wi FI- RESOLVED
 > Mobile Router that will auto connect to Wi FI- RESOLVED
Lantley
Ellicott City, Maryland
Posted: 04/28/21 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking to install a mobile router that will auto connect to my wifi at home and that will auto connect to my hotspot or known wifi source when on the road. I want to set it up once and forget about it. I don't want to reset/reconnect the router at each destination.
Do all models auto connect? Is there a model I should look for?
I'm looking for a mobile router. Should I be looking for a different device?
* This post was edited 05/08/21 09:45am by Lantley *
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
HackerAce
Tualatin, OR
Posted: 04/28/21 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Try this out, we are so happy [emoticon]
https://safarisolutionsllc.com/
John McKean
1999 National Tropical
1965 Shelby Cobra Factory Five MK III Kit
2015 Hyundai Genesis
2013 Polaris RZR 800 S
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/29/21 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Not really clear why you want a router... do you have wired devices you need to connect, or are you just trying to have wifi in your RV?
If it's just wifi coverage, I solved that issue by setting my phone's hotspot to have the same SSID and password as my home wifi. I never turn it on at home as a hotspot so there's no contention. All of the kids devices and our smart TV connect automatically whether we are in the truck or the RV.
Where I think your request falls apart is having a router recognize multiple networks and expecting it to connect seamlessly. Range extenders and access points are more or less configured to look for a single SSID.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
Lantley
Posted: 04/29/21 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Basically I'm trying to keep it simple and avoid setting up all my devices at each CG vs. setting up one device.
Some devices set up easier than others. My RV smart thermostat doesn't like to be set up.LOL
gemsworld
Arizona West Coast
Posted: 04/29/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Just like at home, you can give your mobile router a network name and password, and have your devices connect to your mobile network. However, you're going to have to have your mobile router look for available wifi connections at each location and connect the router to the desired wifi.Once you're connected to the desired network, your devices can connect to your router network.
folivier
Southeast Louisiana
Posted: 04/29/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Is it that difficult for a data reseller to list which service it's actually reselling? Point being that att and Verizon work ok in some areas but not in others. Sprint and Tmobile are even less available in remote areas.
rlw999
Washington State
Posted: 04/29/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Realistically, you're almost always going to be better off with your hotspot than using the free campground Wifi since that free Wifi is almost always so oversubscribed that it's slower and less reliable than using a hotspot. (I've had much better luck with paid campground Wifi, but you need to sign on through a login screen, so it's harder to make it automatically connect).
But even ignoring that, pretty much every campground has a Wifi password and/or guest login screen that you have to click through to gain access to the wifi, so you can't easily automate that. (unless you always go to the same campgrounds and your wifi repeater remembers all of the SSID's and passwords), assuming they rarely change the passwords).
What I do, (which is probably more "high touch" than what you want) is use a small Wifi router in the RV that my devices connect to, since that has a static SSID/password, I never have to reconfigure anything else. Then I manually plug that either into my hotspot router or to a 5Ghz or 2Ghz Wifi repeater with a directional antenna that I can aim at the campground's Wifi source), and I manually set it to the SSID/Password of the campground. Only takes a minute or so to set it up.
I believe this is pretty much what the Wineguard Connect does (which comes in a convenient roof mounted enclosure).
Lantley
Posted: 04/29/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
My cell phone or even my amazon show remembers where it has been and will automatically connect to known sources without any interaction from me.
My cell phone auto connects at my office, at my parents, at my brothers, or any where else I have already set up to connect.
I want an RV traveling device to do the same. I can't believe this device/feature does not exist.
lane hog
Posted: 04/30/21 01:13am Link  |  Quote  |  Print  |  Notify Moderator
So.... why not just use your cell phone as a hotspot if it's already working on all those networks?...
Lantley
Posted: 04/30/21 05:02am Link  |  Quote  |  Print  |  Notify Moderator
My cell phone as a hotspot does not work nearly as well as my hotspot as a hotspot. Furthermore I need to use my cell phone as a cell phone!
If I leave the RV with my cell phone the internet leaves the RV.
Devices and people in the RV would have no internet.
