RV.Net Open Roads Forum: Class C Motorhomes: Rubber Roof help
Open Roads Forum  >  Class C Motorhomes  >  B+
 > Rubber Roof help
Scottiemom
Posted: 04/29/21 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Trip is going very well. Left Florida almost 2 weeks ago and drove to Virginia to see my daughter and family, then headed to Indiana. Arrived here safe and sound. Refrigerator is not working on electric. I knew this before I left, so it's running on gas. I made an appointment with the Amish in Shipshewana. Turns out fridge works fine on electric, but the receptacle in the fridge box does not work. The Amish was not an electrician and didn't want to delve into it further, so I have an appointment Monday with Charger Enterprises in Elkhart to get it fixed. I am camped down at my sister's south of Warsaw. I have electric and water here which is fine.
I have another problem I need help with. I have a leak that is dripping from the roof A/C when it rains. I mentioned to a friend I wanted to get some sealant and reseal around the A/C. He cautioned that because of the rubber roof, I had to be careful what I used on it. So what products should I use? I figure I need a cleaner to clean the area first, then I would add new caulk to stem the water drip. I can go to Factory surplus in Elkhart or Johnson's in White PIgeon and either one should have it. Just wondered what your go-to product is for such a repair.
Thanks!
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
BurbMan
Noblesville, IN
Posted: 04/29/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
On a rubber roof, don't use anything that contains petroleum distillates or mineral spirits. Dicor is the big brand in rubber (EDPM) roofs, and for caulk/sealant you would use lap sealant, either self-leveling or regular.
HOWEVER, there is no caulk around the a/c unit, there is a rubber gasket that seals the a/c to the roof. When the a/c unit is fastened to the roof, the gasket compresses and forms the water tight seal. Many times that gasket will shrink over time, and the unit can be resealed by removing the interior trim and tightening the mounting screws to further compress the gasket. This is a relatively easy process and the RV shop that's fixing your outlet can probably do this in 10 minutes.
IF the gasket is due for replacement, the a/c unit needs to be lifted off the roof so the gasket can be replaced and reinstalled, obviously a much bigger job because those units are heavy.
DO NOT try to caulk or apply sealant around the outside of the a/c, you won't be able to get the caulk in far enough under the exterior shroud to reach the mounting plate, and it will just gum things up if the gasket needs to be replaced.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
ronfisherman
SE Michigan
Posted: 04/29/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Stopping the leak may be as simple as tightening the bolts that hold AC to roof. They can be accessed by removing grill in ceiling to AC. Do not over tighten.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
2oldman
NM
Posted: 04/29/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Could be as simple as a loose wire, disconnected wire, breaker..
Going to a shop for this kind of stuff can get time consuming and expensive. I'd check those things first. A voltmeter is a must-have tool.
bobndot
Posted: 04/29/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
X2. Thats the first thing to try. Worked twice for me.
Krusty
Calgary, Alberta,Canada
Posted: 04/29/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Check all your GFCI outlets to make sure none are tripped. Fridge outlet may be connected to one
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Scottiemom
Posted: 04/29/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the thoughts. With regard to the fridge, there is no juice going to the outlet. Glen checked the converter for broken wires, bad breaker and blown fuses. His idea is the recep is bad or there is a broken wire from the converter to the fridge. He was using a volt ohm meter. Billy was sure they would be able to find it. Every other outlet and everything electrical is working. I have one GFI outlet and I use it every day. I only have 5 inside outlets and they all work. I have 2 outside and they both work.
I don't know how to get the A/C plate on the ceiling off. There are only two visible screws and they look like pop rivets. I will do some checking on it. I'm not sure they will be able to look at that when I get the fridge fixed as I think they are working me in, but I will ask.
Thanks for your help. I know now what NOT to do!
Dale
2oldman
NM
Posted: 04/29/21 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman
NM
Posted: 04/29/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Scottiemom wrote:
Refrigerator is not working on electric. I knew this before I left, so it's running on gas.Turns out fridge works fine on electric, but the receptacle in the fridge box does not work.
Ok, you've lost me here.
a) refer not working on electric
b) works fine on electric
c) what is a receptacle in the fridge box?? I assume the 120v
"With regard to the fridge, there is no juice going to the outlet. Glen checked the converter for broken wires, "
The converter has nothing to do with 120v. Are you talking about an inverter?
Help.
Scottiemom
Posted: 04/29/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Help.
The Dometic Fridge does not work on electric as it is configured. It has an electric receptacle in the fridge box it is plugged into. When set on auto, it runs solely on gas because there is no power to that recep. If you take the cover off outside, you can see it plugged into an outlet. That outlet is not working. It is working on gas. In testing, they found if they unplugged the fridge from that receptacle and plugged it into power via an extension cord, it works perfectly. So it is working on electric and gas, but won't work plugged into the receptacle inside the fridge box. So it is either a bad receptacle or there is a broken wire between the converter and the receptacle in the box.
Perhaps I said it incorrectly, but they opened the box, which I thought was labeled converter. It is where all the power comes in and has fuses and breakers and the power surge protector. Everything in there checked out, and wires go from there throughout the coach. So that's why they checked that.
Dale
 > Rubber Roof help
