RV.Net Open Roads Forum: Tech Issues: City water hookup leaks
 > City water hookup leaks
Bobbo
Wherever I park
Posted: 04/30/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Are you guys saying that the fresh water tank is pressurized?? I doubt it. The pump takes a suction on the tank the water is pulled thru the pump and comes out pressurized.
No one has said that. The water line between the water pump and the faucets is pressurized if the pump is on, or if it holds pressure when the pump is turned off.
Bobbo and Lin
Dave H M
IL
Posted: 05/01/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Dutch_12078 wrote:
If flushing the check valve doesn't fix it, a quick temporary fix is to just screw a garden hose plug into the fitting. If that's not on hand, an inline garden hose shut off valve or even a common 'Y' adapter with shut offs will work.
Yep I carry one of those just in case. That was after the school of hard knocks. [emoticon]
2oldman
NM
Posted: 05/01/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
That's not a temporary fix, that's permanent! [emoticon]
Ron3rd
Upland, CA USA
Posted: 05/01/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Beverley&Ken wrote:
There is a one way valve just inside the city water hookup, actually it is part of the hose input. Inside the fitting is a one way valve that sometimes becomes dislodged, Most common after winterzing.
The part us not expensive, approx $10. Easy to replace, on the outside of the RV, remove the screws holding the inlet, pull out slightly and replace with the new. New caulking and done.
Ken
This is true; and they make an all plastic version (which your probably have) and a superior version with a brass connection at the backside.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
jornvango
Full-time RVer
Posted: 05/01/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
First I have to find the tool to be able to detach the hookup! I thought I carried a bunch of screwdriver heads but the screws on the hookup look like something I haven't seen before. I'm not sure if the screws are standard across RV brands but mine looks like it needs a 'tri-wing' head. (which I don't carry)
capacitor
California
Posted: 05/01/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
A torx? It is star shaped. A Robertson is square.
Ron3rd
Upland, CA USA
Posted: 05/01/21 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
jornvango wrote:
Thanks!
Only 2 I've seen on my last 3 trailers are the square drive or Phillips head.
JimR 1
Custer South Dakota
Posted: 05/03/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Ooopppps
jornvango
Full-time RVer
Posted: 05/10/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Per the Casita service department, it is a rivet, not a screw. Doh!
That being said, I cleaned it out and it's not leaking any longer. I think washing the trailer with high pressure must have moved the rubber seal.
Thanks!
