RV.Net Open Roads Forum: Truck Campers: New Fords Weigh Themselves
 > New Fords Weigh Themselves
rhagfo
Portland, OR
Posted: 04/30/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I chuckle at this, had a neighbor in the early 90’s that ran his own log trucks, had load cells installed on the bunks so he knew his loaded weight before leaving the landing.
The interesting thing thing was he could run his truck in three different configurations with or without pup trailer.
JRscooby
Indepmo
Posted: 04/30/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
jaycocreek wrote:
Just about all logging trucks have scales and they can be quite accurate..
+- 300 lb ?
With the pressure gauge on Pete, and Air Weigh on the RGN, I would be within 60 lbs of what Cat said. And with the pressure gauge on my Mate end-dump just as close.
JIMNLIN
Oklahoma
Posted: 04/30/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
The new F150 has around 22 different GVWR ratings from a 6010 gvwr up to 7850 gvwr. Example is the 6750/6800/6950/7000/7050/7150 gvwr.
WE know some F150 gvwr payloads can overload the its RAWR numbers so I would think Ford would go with axle load scales like I've seen on bigger trucks/trailers.
Hemi Joel
Minnesota
Posted: 05/02/21 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Unbelievable that Ford would think any fools will fall into this trap. Pay $600+ for a system to rat you out to the highway nazis and the truck warrantor if you go over weight? Void the warranty on the engine, the trans, the whole truck, because the violation is stored in the PCM? Get pulled over and fined/impounded? Good luck selling that one, Ford.
Edit: On second thought PT Barnum was right. These things will sell like hotcakes.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
GDS-3950BH
DC
Posted: 05/02/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
The $600 honeymoon and the oooohs and ahhhhs will end in short order the minute a sensor or module goes bad, and it costs 2 or 3 times the cost of the original option to repair. Next they should install toilets with an auto wipe feature in their trucks, and put highway rest stops into the obsolete column
JRscooby
Indepmo
Posted: 05/02/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO, the warranty issue is likely real. Would not surprise me to learn people are paying extra to test the systems in real world. If they can sell it for $600, find out it works it is likely cheep enough to install on all trucks. If customer asks for it, they pay and get the light show. Don't ask for, don't know they have it until warranty is denied.
The fine/impound snot? No.
3 tons
NV.
Posted: 05/02/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
This device has been on the aftermarket for quite some time - just a computer dongle that correlates already existing OBD II drivetrain data, however it won’t know if you do a suspension mod...Ford simply made it a pricy option integrated into center screen...
Mfg by Curt, available at etrailer
3 tons
jimh425
Western MT
Posted: 05/02/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ford doesn’t try to make it work for every vehicle out there while Curt did. Fitness RV did a test and it wasn’t very good results. The engineers came out and did some work to try to make it better.
My guess is that Ford’s solution “could” be far more accurate although not perfect over time. Springs do change over time.
For me though, I’m not sure why I care other than having the latest tech gadget. Not that I’m against tech as a person who retired from it, but at some point, you are paying for gadgets that rarely have a need. For instance, for this “feature” what would you do if you found out that you were x% higher than you wanted to be. Maybe the first time, you take stuff out. After that, I think most would just go for it. That’s about equivalent to going to a CAT scale once, but of course, the Ford solution would be far more expensive.
joerg68
St. Ingbert, Germany
Posted: 05/04/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
There is overweight, and there is overweight.
Taking a load of tiles home from the nearest box store 5 mls down the road is not the same as a six week cross country trip with a heavy camper in the back and a toyhauler on the hitch...
The truck won't know the difference...
Either way the driver needs to know what the truck can safely do.
