RV.Net Open Roads Forum: Tech Issues: INSTALL TILE TAKE UP CARPET
 > INSTALL TILE TAKE UP CARPET
bigred1cav
ohio
Posted: 04/30/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I need detailed instructions on removing the carpet and replacing it with tile of some sort. Photo's also, I know nothing of how to approach this task
Thank all of you
Williams AZ area
Posted: 04/30/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Lift up a section of carpet to see what you are dealing with...if you could lay the tile without modification.
dedmiston
The West
Posted: 04/30/21 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Moved from RV Parks, Campgrounds, and Attractions.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
valhalla360
No paticular place.
Posted: 04/30/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
What are you putting the tile into?
- A heavily built diesel pusher with 3/4 plywood floor and plenty of stiff joists, it may be viable.
- A lightly built low end travel trailer with the foam plywood sandwich floor, expect a lot of cracked tiles in a short time period.
Also, you need to consider the operation of the slides. Many are designed to use the carpet as a surface to slide on...hence why the industry moved away from vinyl flooring.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
gbopp
The Keystone State
Posted: 04/30/21 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check YouTube? That may have the detailed instructions you need.
monkey44
Cape Cod, MA and Central Fla
Posted: 04/30/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if you considered alternatives, but interlocking engineered hardwood or laminate is much easier to install. If you buy a good grade, not cheapo, it's probably even less cost than tile and has no cracking grout or separating seams. And it will take road vibration without problem. Most flooring stores carry it, including HD or Lowe's. It generally has a forty-year surface wear warranty.
You can buy it in varied designs, including a Tile-Look.
I installed it in my home and my RV. Would do it again in either ...
I recommend looking at it before you begin a tile operation.
PS... Carpet is easy to rip-out. Then tear out the tack-strips that hold it down, and any random staples ... make sure you get every one.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
fourthclassC
MA
Posted: 04/30/21 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice here. I removed my carpet (except for under the dinnnette table because it was still nice) replaced it with a left over piece of linolium. Came out great. Got a aluminium strip (forgot the real name) for the transition at the edge under the table.
bukhrn
Lanexa, Va
Posted: 04/30/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
... tile of some sort...
Not sure if he's talking, Actual Tile, or a linoleum type squares. Big difference in weight and ease of installing.
2007 Forester 2941DS
2014 Ford Focus
magnusfide
On the Road Again and Again and Again...
Posted: 04/30/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
This page of Youtube search results shows both. Scroll down to see the carpet removal vids.
First law of science: don't spit into the wind.
Bacon is the duct tape of the kitchen.
Magnus
JimK-NY
NY
Posted: 04/30/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Either way I would avoid "tile". Actual ceramic tile is thick and heavy and prone to cracking in an RV. Linoleum tiles need to be glued down so you need a proper substrate and if they lift getting them up is going to be a nightmare.
Use sheet goods instead. It does not need to be glued, will not peel up or crack.
Actually I went to from sheet linoleum to carpet several years ago. I really like the carpet on cold evenings when it feels great to kick off the shoes after a day of hiking. I though it would be hard to keep clean but I pull out the entire piece and shake it. It is indoor/outdoor carpet so I can even wash it.
