RV.Net Open Roads Forum: Fifth-Wheels: Broken rear window
 > Broken rear window
Page of 5
Cummins12V98
on the road
Posted: 05/03/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
GMH wrote:
Yeah, I bet a nice heavy coat of silicone or tri-lube spray will help that slide back into place easier.
Use glass cleaner.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
NOBLNG
canada
Posted: 05/03/21 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Use glass cleaner.
The glass will already be mounted in the full aluminum frame when I get it back from the glass shop. It is just a matter of forcing (very carefully) the extruded aluminum frame back into the rubber molding at the top edge. That wide horizontal band across the top of the window in the picture is a stiff rubber molding that the extrusion fits into, and the brackets that the frame gets screwed to interfere with just pushing it straight up into place easily. I will let you all know how it goes when I get the window back.
Thanks.
* This post was edited 05/03/21 09:33pm by NOBLNG *
GMH
Canada
Posted: 05/03/21 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
My apologies folks. I have inadvertently created two accounts here and posted under two usernames. I have notified the moderators to delete one.
Cummins12V98
on the road
Posted: 05/04/21 02:14am Link  |  Quote  |  Print  |  Notify Moderator
Like I said use glass cleaner.
BobsYourUncle
Calgary Alberta Canada
Posted: 05/04/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
X2 ^^^
Don't use any lubricant. It will work good but will leave an unwanted residue.
Glass cleaner will work perfect, and it is water soluble, and will evaporate.
Another thought, is there room to close the operator, push the window more straight up to get it into the rubber, then open it to put the screws back in?
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
GMH
Canada
Posted: 05/04/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Ok, glass cleaner it will be. I will have a better look today but this is what I imagine the molding/frame connection is like? I think the frame was cast into the molding. I did try removing it with the window in all positions from wide open to nearly closed.
NJRVer
NJ
Posted: 05/04/21 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
GMH wrote:
I got the frame out, but It sure didn’t want to come out easily! Being the top one it is somehow hooked into the rubber molding above it. The glass shop is charging me $85. to replace the glass. My fear is that I will break it trying to re-install it. I went to the Keystone dealer and they said it is a Kinro window, not Lippert. They didn’t have any service info on it, so I have e-mailed Kinro to see what they recommend. If I do break it, I will put plexi glass in the second time! Wish me luck.
Tempered is very tough. Just don’t hit the edge as it may shatter into little cubes.
Agree.
I am a door contractor and I have taken tempered glass and flung it into the dumpster and it will just bounce around. Laying flat you can stand on it.
But just a light TAP with a hammer on the edge....POOF!!!! lol.
Cummins12V98
on the road
Posted: 05/04/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
NJRVer wrote:
Agree.
YEP, finishing mortising in an entry lock when I was a Carpenter Apprentice and gave the hole one last tap with the chisel and the glass panel exploded into thousands of pcs. I was shocked and felt horrible. Told the Boss and he said "not the end of the world" and I felt a bit better.
We would lay 3' x 9' x 1/4" panels on a tarp and straddle the corner, lean over with a hammer and lightly tap the corner. Pull in the corners of the tarp and lift and place into a debris dumpster and take then done the freight elevator and then into the dumpster.
GMH
Canada
Posted: 06/02/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Well I get my window back tomorrow. I hope it goes back in relatively easy. I will use some windex for lube.
BobsYourUncle
Posted: 06/02/21 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Great!
Good luck with the re-install.
It should go in easily.
Let us know how it turns out.
Page of 5
