RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel or gooseneck?
 > 5th wheel or gooseneck?
Cummins12V98
on the road
Posted: 05/01/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
" I can take the head off and remove the hitch relatively easy (and I am 65 years old)."
Manly Man I say!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TravelinDog
Nevada
Posted: 05/01/21 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
What do you guys think about the Anderson hitch with the kingpin coupler? Seems like it would put no more strain than a traditional 5th wheel hitch on the frame of the 5er.
I like the fact that it only weighs 40-45lbs and is easily removed when not needed.
fj12ryder
Platte City, MO
Posted: 05/01/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
"Ruh roh," he said, as the thread prepared to drop off the cliff. [emoticon]
Howard and Peggy
"Don't Panic"
fj12ryder
Platte City, MO
Posted: 05/01/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Andersen vs "TOG"(The Other Guy) threads tend to become pretty contentious at times.
I'm a B&W fanboy, but IMO if you stick to 5th wheels of 10,000 lbs. or less, the Andersen is an adequate hitch. But as I said, JMO.
Endricken
Alabama
Posted: 05/01/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
The Star Performance Kingpin Gooseneck adapter has worked well for me since 2007... Usually I can get the adapter on my ball easily and never worry about it slipping off.
https://www.sphitch.com/
The Reese Goosebox failed on me and was not replaced under warranty after it failed (Front Frame broken and Reese Goosebox movable part was BENT after hitting a TX pothole). Didn't like how it was supposed to be greased (via zerk) for every tow or how the airbag puffed out enough air after almost every tow it had to be refilled VERY slowly (have air compressor on board?)... maybe the design has improved?
Coworker with same trailer as mine is using the Anderson Hitch successfully too - but doesn't tow nearly as much as I do.
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
Ron3rd
Upland, CA USA
Posted: 05/01/21 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
The Andersen is a great option. People that understand it often end up buying it.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Ron3rd
Upland, CA USA
Posted: 05/01/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah but it's only adequate up to 18,000 lbs.
Cummins12V98
on the road
Posted: 05/02/21 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Concur
JIMNLIN
Oklahoma
Posted: 05/02/21 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Pullrite ISR 52 lb hitch
PullRite has the same GN ball style hitch as a Andersen...weighs 52 lbs and 20k lb draw /4k lb load rated. Check them out
Hitch brands are like truck or trailer brands...everyone has their favorite and mine is the best.
Cummins12V98
on the road
Posted: 05/02/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
I like the Pullrite mentioned but don't like the fact you need some sort of adapter.
