RV.Net Open Roads Forum: Truck Campers: Built-in generator oil change
 > Built-in generator oil change
AH_AK
AK
Posted: 05/01/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
The built-in generator (Onan 2500 LP) in my Bigfoot needs an oil change, but you can’t access the drain plug from below (battery compartment). Anyone done this? Do you just unbolt and slide it out far enough to access the drain plug.
Slymer
Ontario, Canada
Posted: 05/01/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Our AF811 has the same generator. I was able to access the drain plug but just barely. Once I found the correct socket & extension bar I had to get it ALMOST on the bolt, on quite an angle & whack with a hammer a couple of times. The bottom cover plate finally shifted over a bit to get the socket dead on. Not easy,....even harder to replace the bolt. You may have to drill an access hole through the bottom cover plate in your set up.
AH_AK
AK
Posted: 05/01/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
So yours had a hole drilled for the drain plug when you bought it? That would make sense but it doesn’t look like mine has such a hole. There is an angled hole to the battery compartment (below) but that appear to be an access for the spark plug (per onan manual).
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 05/02/21 05:22am Link  |  Quote  |  Print  |  Notify Moderator
If you do get it out, maybe a Fumoto valve would work, Instead of drilling a hole, you can attach a hose to drain.
I have used them in my trucks for many years.
2021 F-350 Platinum 4X4 PSD SRW 2016 Montana 3950FL (2) Honda EU2000i's
...and a few (twenty-some, but other than my wife, no one is counting) antique Allis Chalmers tractors
KD4UPL
Swoope, VA
Posted: 05/02/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I would probably just suck it out the fill port. There are vacuum pumps made for this. They are most often used to change the oil on inboard boat engines. A look thru a marine website for oil change pump should get you there.
jimh425
Western MT
Posted: 05/02/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I suck mine out the fill port.
AH_AK
AK
Posted: 05/02/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Great idea. I think pumping it out of the fill tube is far preferable to removing or drilling holes.
notsobigjoe
southeast
Posted: 05/02/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes and I agree to the three above. That's how I did it before I took it out and threw it in a ditch.
brholt
Seattle
Posted: 05/03/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
On my old AF1150 the hole in the "shield" didn't line up with the drain plug. I took a Dremel and made opened the hole to an oval shape to allow me to access the plot
AISURFFISH
BERLIN MARYLAND
Posted: 05/06/21 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Thats what she said..
Quote the Office
2017 F350 6.2L Crew Cab
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
