RV.Net Open Roads Forum: Class A Motorhomes: Disc brakes temperatures
 > Disc brakes temperatures
MrWizard
Traveling
Posted: 05/02/21 01:33am Link  |  Quote  |  Print  |  Notify Moderator
What is average, what is good, what is bad
I bought a temp gun, to check tire temps and realized it could also be used to check wheels bearings and brake parts
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
JRscooby
Indepmo
Posted: 05/02/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
I can't say what temps to expect but unlike drum shoes, the disc pads rub all the time not just when brakes are applied.
Quartzsite, AZ
Posted: 05/02/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Never seen those numbers. Average your temps for a couple of weeks? “Shoot” other RVers’ wheel temps?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MountainAir05
New Mexico
Posted: 05/02/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Think you are going to have a hard time. Brake pad are made from different material and each will have they own temp readout. Disc will be one temp, and drums will be another. You might find the info from whom made your brake. On my sport car my pad are cooler than on the AWD 4 runner. They both have Disc and both are very good brakes. Have fun with your new toy.
Just went out and check the sport car and it show in history that the pads run right at 185 average. All 4 are different and the 185 was the middle range. They are 5+ degrees different with the fronts the highest. My front pads are one brand and the rear another. On braking hard it shows 250 plus.
* This post was edited 05/02/21 08:29am by MountainAir05 *
Matt_Colie
Southeast Michigan
Posted: 05/02/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
As someone that has been doing this for years, I can tell you that the results can be confusing until you understand what you are looking at in very complete terms.
The walk around did tell me that a rear wheel bearing was just a little too tight. The red numbers were right and I got that fixed before it became an expensive issue.
Our classic (boarding on antique) coach is a disk and drum set. I am also paranoid because it is old (so am I) and I really like to head off problems before they are expensive. We did have a caliper hang up and the routine temperature walk around told me about it early on and it was an easy fix.
What did puzzle me most was that when I did the walk at a mid-day stop, all the brakes on one side were hotter than those on the other.... We had been going west and the left side was hotter. When I was the reverse when we were home bound....
We now have an IR gun dedicated to the coach.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Bruce Brown
Northern NY
Posted: 05/02/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Whenever I do brakes on cars (which is often) the biggest thing I look for is equal temps on both sides. As long as they're about the same I call it good to go.
If something isn't right the gun will let you know it.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
MrWizard
Traveling
Posted: 05/05/21 02:50am Link  |  Quote  |  Print  |  Notify Moderator
I did a Google check on that very topic because a friend of mine thinks like you do, and I think differently, I think there is suppose to be an air gap
Pads that touch mean friction and drag, they will wear more, wear it faster, and get hotter,
What I found was the statement and drawings, that when brake pressure is removed the bellows style piston cover retracts the piston and disc/rotor "run out" forces the pads away from the surface allowing for an air gap between pad and rotor, no value was given for the size of the gap
They do not touch when wheels are turning aka driving down the road
Think about this
A tire with a 4ft circumference will spin 1300 times in one mile, if you are driving 60mph that tire is spinning at 1300 rpm , if a brake pad is touching the disc rotor, it and the rotor are going to get hot, that is what friction does, brake pads have lots of friction capability or your vehicle would not stop
* This post was edited 05/05/21 02:59am by MrWizard *
MountainAir05
New Mexico
Posted: 05/05/21 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Think about this
Go to a car race at night and it might make you rethink or every car out there is not set up right. I also think there is a gap " very small" but seeing them glow is another story. I have pulled brake pad off right after driving and you must have good gloves on to take them off. But I agree with you on the gap. I try to get runout to .002 or zero if I can. You will know it when they go out of round. Vehicles with a good brake job will not build up of rust or other stuff on the rotor due to the very low runout. They shine. Remember they are floating calipers.
