RV.Net Open Roads Forum: Class A Motorhomes: Need recommendation for a replacement inverter
 > Need recommendation for a replacement inverter
fijidad
Escondido, CA
Posted: 05/02/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
The inverter in my 2002 Monaco Windsor is on the blink and I'm looking to replace it. Does anyone have a recommendation for a supplier of replacement inverters?
Anza-Borrego Desert SP area
Posted: 05/02/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
With what capacity?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 05/02/21 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want to go cheap or top flight?
Also what is there now
Cheap.. The Xantrex Freedom line... My only real complaint is the 120vac wire connections are ... not all that good (I only broke two of 'em)
Top line... something like a Tripp-Lite
Do go True(or pure) sine wave
But note that the Tripp-lite will not fit in the hole left by the Freedom which is why I askwd what is there now .
naturist
Lynchburg, VA
Posted: 05/02/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
inverter or converter?
Tinstar
McKinney, TX
Posted: 05/02/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
It's going to be an inverter on a Windsor.
">Never pass up a chance to go somewhere">
ArchHoagland
Clovis, CA, USA
Posted: 05/02/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious what kind of problem you are seeing.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
time2roll
Posted: 05/02/21 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Best to post the make and model number for the existing inverter for best answers. Most do not drive a 2002 Monaco Windsor.
675w Solar pictures back up
Branson N Tucson
Tn
Posted: 05/03/21 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Xantrex?Freedom is a piece of junk.Talk about junk.
Had and issue with one that was put in. The inverter malfunction several times, was less than 3 months old. Contacted the warranty number and told to drive to a advisor in Houston, turns out the advisor worked out of his garage at his house. He told me inso many words to pound sand. They do not back their products. Wa told that the Freedom inverter was junk by a lot of RV dealers.
FloridaRosebud
Melbourne
Posted: 05/03/21 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Indeed, I'm having the same issue here in FL. The "service center" is a single guy in his garage over in the Tamp area. Took him 4 months to tell us a surge got it, so they are not covering the warranty. It failed the first week it was installed, and I was just traveling, not hooked up to any shore power. So stay away from them, they do not back their products.
Al
folivier
Southeast Louisiana
Posted: 05/03/21 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Victron, Magnum, Outback are all top of the line with great support.
