RV.Net Open Roads Forum: Class A Motorhomes: Need recommendation for a replacement inverter
 > Need recommendation for a replacement inverter
fijidad
Escondido, CA
Posted: 05/04/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
ArchHoagland wrote:
I'm curious what kind of problem you are seeing.
That's a good question...something I've been pondering since you asked it. The problem I'm having is that the refrigerator will not run in inverter mode. Runs fine when we're plugged in, but not otherwise. There are beeps, and codes that I don't fully understand, but the bottom line is it doesn't run the refrigerator.
I'm taking the rig in today for work on a list of things that need attention, and this is on that list. I'll report back what they say.
ArchHoagland
Clovis, CA, USA
Posted: 05/04/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
When you say refrigerator...is that a typical RV refrigerator with gas or electric option or is it a residential refrigerator?
What brand/model refrigerator?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
fijidad
Escondido, CA
Posted: 05/04/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
It's a typical gas/electric refrigerator...don't remember the brand name and we just dropped it off at San Diego RV for work on a list of things. I was able to confirm the inverter is working by turning on a portable fan that runs on ac. But the refrigerator has an error code that says "no ac." And yet, when we're at an RV park, it runs like a champ on ac. So, still confused about it not running off the inverter.
ArchHoagland
Clovis, CA, USA
Posted: 05/04/21 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen complaints from other people who had problems running refrigerators off of inverters.
I suggest you do some more research before replacing the inverter.
fijidad
Escondido, CA
Posted: 05/04/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Good call, and I agree. This may be something to do with the refrigerator instead. Hopefully something "simple." Read inexpensive. If there is such a thing in owning a motor home.
Sandia Man
Rio Rancho, NM
Posted: 05/04/21 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
First, our Xantrex 2K watt inverter charger has performed flawlessly whether providing 120Vac to our coach or charging our 4 golfcart batteries. Second, we have the larger 4 door Norcold in our rig and inverter is not wired from the factory to power our fridge. I asked the previous owner and they stated the factory told them no need as propane mode is commonly used when off the power grid.
On my last rig I installed a dedicated inverter for our RV fridge thinking I would save on propane and not have to have it in gas mode while traveling. Neither assumption were truly vindicated, we found batteries down upon arrival, not good when you are boondocking. Our RV fridges have always performed well across many rigs, they stay cold for hours, we use propane mode as needed while traveling.
MrWizard
Traveling
Posted: 05/05/21 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Running/powering and RV fridge from the inverter is a waste of battery power, 300+ watts for the heating elements uses 30 to 40 amps D.C. Battery power into the inverter to get the 3 amps 120vac for the fridge heating elements,
The best thing is to use propane for the fridge when not connected to shore power, this RV has an RV gas electric fridge, I power it exclusively from LP unless I run out of propane, in which case I switch to electric and inverter while I drive to the LP station,
For 7 years with a previous RV I did power a residential fridge from inverter, with 649watts of solar pane on the roof and 500+ AmpHrs of battery bank, that fridge compressor only need 100 watts of electric power
RV gas electric absorption fridge need 3 to 4 times as much electric power,
I use l.p. And keep electric as emergency backup operation
With this fridge
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
fijidad
Escondido, CA
Posted: 05/11/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I just heard back from San Diego RV, and they said the inverter only powers the ice maker, not the refrigerator; and that the refrigerator needs to run on propane.
Now, we can do that, but the refrigerator works fine when we're plugged into the RV Park pedestal...and the propane is off.
So why wouldn't it work off the inverter?
grldst
Dallas, GA
Posted: 05/11/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Been RVing for 30 plus Yrs. Boondock 2-3 months a yr. have had 4 different motor homes with Xantrex inverters and have never had a problem with them. There is a guy in Metro Phoenix area that sells refurbished xantrex. Guarantee them and reasonable price. Should pop up with a google search.
time2roll
probably not connected to inverter power.
675w Solar pictures back up
