RV.Net Open Roads Forum: Class A Motorhomes: Fish bowl cooling class A
 > Fish bowl cooling class A
JCat
Big Apple, SoCal, Big D, everywhere USA
Posted: 05/03/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
I have always had a problem cooling and heating the fish bowl on my RV.
The dash air has never cooled the fish bowl and the front air does not send enough air while driving to the front.
I’ve tried directing the flow to the front, using a fan to push the cool air to the front, nothing works.
Also I do drive mostly out west with temps over 90 many times.
So has anyone done any creative ac mods to help this situation ?
Like replacing the dash ac system and putting in something that works, or adding some type of stand alone ac unit in the front ?
Let me know
Jcat
2004 Mandalay 40 D
JCat & PCat
2004 Mandalay 40D
CAT C7 350 HP
folivier
Southeast Louisiana
Posted: 05/03/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Try and time your driving so you're not driving into the sun.
Let me guess, your coach has dark paint in the front? I've had 2 like that and repainted the current Foretravel with light colors and it makes a big difference. I use a Dewalt battery/120vac fan to more the air on me and keep the shades down as far as I can to keep solar gain off me.
wildtoad
Blythewood, SC
I have to assume your 40’ motorhome has multiple rooftop AC’s or similar, as well as a generator sufficient to run all of them. Start the generators and turn on the AC units. If the dash AC has a recirculate option so turn that on too. As the cool air from the roof mounts get to the floor it should go up the return for the dash ac and help it cool better as well.
Where traffic conditions allow, we pull the side shades facing the sun down far enough to block the sun but not to interfere with viewing the mirrors. Do the same for the front shade down to help block out the sun.
* This post was edited 05/03/21 10:09am by wildtoad *
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
JCat
Posted: 05/03/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Tried the Fan, not good enough.
Have 2 ac units on roof, they don’t cool the fish bowl when driving.
Sorry I can’t drive away from the sun or time trips for early morning or later evening.
Have cooled the fish bowl before start of trip and it stays cool for a while, then it gets hot.
Maybe I should install one of those residential attic fans in the ceiling?
Maybe not, would get me wet when it rains
Y-Guy
Tri-Cities, WA
Posted: 05/03/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
We took a trip to southern Utah, temps 118° in Kanab - ugh. Running the Dash air and both roof top it was still warm. I had 2 fans blowing air from the back, helped a bit but still hot. When we parked and had our solar shade and curtains closed we could get the RV fairly cool, but not when traveling.
On another trip we did try hanging a thick shower curtain just behind the driver/passenger seats, dash air wasn't enough so we fired up the generator and had 2 of the air top vents pushing air up front and the dash. That helped but the dash just isn't powerful enough.
Reality is that it's just not well insulted enough and the front end with all that glass makes it worse. I suppose a stand alone might help, but we've just tried to avoid driving after 2PM in hot climates. I live in the desert so we've learned to adapt. What's the size of your roof top A/Cs?
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
rgatijnet1
Posted: 05/03/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Try a portable AC unit that is vented to the outside and directing air right in to the cockpit, in addition to your two roof top AC units.
JCat
Posted: 05/03/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Roof ac units are the high capacity 15 amp and not too old. When parked they do a great job.
Yup been thinking about a portable ac unit as well. The ducting to a window might be a PITA.
Would love to hear from anyone who has done this.
Was also thinking of those units they hang over the door of businesses they put out a lot of air
dodge guy
Bartlett IL
Posted: 05/03/21 11:14am Link  |  Quote  |  Print  |  Notify Moderator
How do you keep the water in the bowl on rough roads?!!!!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Sandia Man
Rio Rancho, NM
Posted: 05/03/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Obviously a bugaboo for motorized RVs, the larger they are the worse it is for driving in triple digit temps. All the ideas mentioned above can have some effect for some, more than likely not dramatic enough for most. We purchased our current class A in Texas and picked it up in late July enduring record temps that hovered around 115 degrees.
Previous owners replaced dash AC in hopes of making it more bearable, indeed air out of vents was really cold but the time it reached us in cockpit seats it simply did not do the trick. You can throw a bunch of money at it with minimal results, kind of like trying to get better mpg, best and most effective method is to just drive a bit slower.
We found if we just left a little bit earlier when temps soared by noon we were at least accustomed to it, thankfully my DW and I were born, raised, and lived most of our adult life in Phoenix and are able to tolerate heat somewhat. Hopefully you find a method that at least makes it more bearable, I know it would be helpful for so many with same issue.
dougrainer
Carrolton, Texas
Posted: 05/03/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
1. I have 50 years in the RV industry. NEVER heard the term "Fishbowl". WHERE did you get that saying?
2. I would try to get a 2 inch type Dash AC flexible hose and fabricate a way to connect to the forward Roof AC AC vent and use clips to allow that cold air from the Roof AC's to blow cold air up to your "Fishbowl". Also, you don't state, but just what is the Dash AC output temp at 60 mph on MAX/Cool? It should be under 60 degrees closer to 50 degrees. If NOT, then that is your problem. I doubt your driving temps are lower than North Texas in the summer(90 to 105). I never have complaints from my Customers that after the roof and dash were working to spec, they could not stay comfortable. We sold Mandalay 15 years ago and never had cooling complaints in transit during the hot summer months. You probably have both roof and dash systems not to spec. Doug
