RV.Net Open Roads Forum: Class A Motorhomes: Fish bowl cooling class A
 > Fish bowl cooling class A
RetiredRealtorRick
Gulf Shores, AL
Posted: 05/03/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Install a 35% tint on the front side windows and a 70% on the full windshield.
. . . never confuse education with intelligence
chuckftboy
Fleming Island, Florida
Posted: 05/03/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
You say the roof a/c's are high capacity and cool well when parked. If the heat is an issue while traveling and not when parked check you firewall for air leaks. Often manufactures are sloppy sealing penetration's for hoses, wires and steering columns. Air pressure on the front of a coach can push a lot of hot air through a coach and out slide seals, windows and around fans.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
dougrainer
Carrolton, Texas
Posted: 05/03/21 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
ANY tint in the field of vision on a Windshield is illegal in almost all states. Doug
dougrainer
Carrolton, Texas
Posted: 05/03/21 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
OK, IF the roof AC and Dash AC check out to spec, odds are you have front Firewall air leaks. The best way to determine where the gaps and holes are is to do this at night if you do not have an enclosed garage. I use both a 300(Smaller than the 500) and 500 watt Halogen work lamp. You first install the lamps INSIDE under the dash and drivers and Pass area pointing at the Firewall. Then go outside and find the various areas showing the light. You WILL find areas. Then have someone move the lights around and at various angles to find all the gaps. I use both Spray foam and Black Silicone to seal the various areas where the light comes out. Once you have found and sealed all areas, you then install the lights out front pointing in and around the Genset. Go inside and find all the areas if any left of light and seal those areas. You will be amazed how many gaps you will find. Remember, ANY air gap will allow 95 degree heat inside at 65 mph. PLUS, If the Genset is running there is additional heat source that will allow hot air to come inside those gaps. NO AC system can overcome this type Hot air intrusion. This also fixes the cold weather problem where the Dash Heat cannot keep up in cold weather. Doug
PS, I have been on motorhome Internet Forums for more than 22 years(various OEM's and owner forums) and never had that Fishbowl term come up. I asked but you did not answer. WHERE did you hear that terminology?
JCat
Big Apple, SoCal, Big D, everywhere USA
Posted: 05/04/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys all good input for changes and things to check.
Especially running a separate duct from the front ac to the **** pit area.
I also heard about the tint, which is supposed to cut down on the heat and is not dark or visible as a tint to Johnny law, po po, 5 O, occifer, smoky, (more new words for your vocabulary) ??
JCat & PCat
2004 Mandalay 40D
CAT C7 350 HP
RetiredRealtorRick
Gulf Shores, AL
Posted: 05/04/21 10:04am Link  |  Quote  |  Print  |  Notify Moderator
I've had 70% tint on full windshields for decades now, cars and motorhomes. LEO's aren't looking for that -- they're looking for the real dark stuff. Visibly, you couldn't tell the difference -- neither could I -- but when it comes to cooling .... wow!
johnhicks
Wandering below the Gnat Line
Posted: 05/04/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
I read "fishbowl" in the rv forums at least 10 years ago, perhaps this one.
-jbh-
dougrainer
Carrolton, Texas
Posted: 05/04/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Only two states — Ohio and North Dakota — allow you to tint the entire windshield, but it has to be 70 percent or lighter.
Is front windshield tint legal in Alabama?
Only the upper six inches of the front windshield may be tinted. The material applied must be transparent. All other windows (side and rear) may have tinting that allows at least 32% light transmission with a 3% tolerance. The reflective material may not reflect more than 20% of light.
How much is a ticket for Window Tint in Alabama?
Window film can keep your car looking and feeling cool, but there's nothing cool about paying a $100 fine for violating Alabama window tinting regulations. .Apr 17, 2018
RetiredRealtorRick
Gulf Shores, AL
Posted: 05/04/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmmm, food for thought. I wonder how many 70% windshield tint tickets are issued in a year in any given state? Maybe you can research that for us. I know I'm probably the only one on this entire forum that has full windshield tint, and probably the only one that violates any other obscure laws as well [emoticon], but it would be interesting to find out (even though my car isn't even registered in Alabama)
