RV.Net Open Roads Forum: Fifth-Wheels: Slide Adjustment
 > Slide Adjustment
Chippendale
Georgetown, TX
Posted: 05/04/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
I found a hairline crack in the gel-coat running at an angle up from the upper front corner of my off door kitchen slide. I have also noticed that there is a "roller mark" in the laminate floor from when the slide is closed. I am assuming that the slide is out of adjustment and that is what caused the mark in the flooring and also the small about 6 or 7 inch crack in the gel-coat.
My question is, how complicated is it to adjust a large slide and about what should I expect to pay to get it done. As for the fiberglass repair, I use to have a boat and think I still have those guys on direct dial. I would appreciate a ballpark figure on the slide adjustment. I was thinking about having all three of the slides checked and adjusted as needed at the same time.
Thanks in advance.
MFL
Midwest
Posted: 05/04/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
If you can contact a local mobile RV repair person, he could come to you, check slide operation, give estimate of adjusting if needed.
Jerry
 > Slide Adjustment
