RV.Net Open Roads Forum: Class C Motorhomes: Where to begin
 > Where to begin
SJ-Chris
San Jose, Ca
Posted: 05/06/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Below are two checklists I use...One prior to each trip, and the other is my Purchase inspection checklist. It would be a good way for you to asses the situation on your RV. Some of the items may or may not apply. If you go through all of these items you can make a list of what works and what doesn't work on your RV. Then create an estimate on how much it will cost to fix each item. I like the above recommendation about multiplying by 1.5x as a buffer. Then you will have a total amount. Then ask yourself...."Can I just go and buy something newer that doesn't have all these problems and pay the same amount?" Your RV right now might only be worth $2000-$5000. If you put $20,000 into fixing it, it will probably be worth $10,000-$15,000 to someone else. Keep that in mind.
I've learned that RV mechanics/repairs are EXPENSIVE, they take a LONG TIME (usually backed up), and most RV mechanics aren't as good as you'd like (....and some are downright criminals). Even though I'm a busy guy, I've learned to embrace the fact that *I* need to do much of the repairs on my RVs myself. These forums are great for advice on how to fix things, and there are youtube videos on just about everything. Instead of paying my RV shop $100/hr, I do it myself. If it takes me twice as long to do it, it's like paying myself $50/hr to do the work myself. I have also gained a deeper understanding as to how everything works on my RVs and a deeper appreciation for things that work. If you are sending your RV out for all repairs all the time, it will cost you a fortune.
If your expected renovation cost is too much, you might be better off saving the money, donating/selling the RV, and then using the money to RENT a working RV the next 5-10 times you want to go RVing (...and save yourself all the headaches, hours spent on fixing it, cost to insure it, cost to store it, etc).
Hope that helps!
Good luck!
-Chris
Prior to Trip Departure Checklist:
o Check the propane level to make sure it is near full
o Check that the refrigerator/freezer is working
o Check that the stove and microwave oven are functioning
o Check that the AC and the furnace are functioning properly
o Check that the hot water heater is working
o Check that the carbon monoxide detector and LP Gas detector green
indicator light is showing them to be functioning (note: House battery
switch by entry door must be in the ON position in order for these to
function)
o Test the smoke detector to make sure it is functioning
o Make sure the fire extinguisher is properly charged
o Check that the generator is functioning properly
o Verify that the engine alternator is properly charging all batteries (engine and house batteries) when engine is running
o Verify that the house batteries are charging if the generator is on or the RV is plugged into shore power
o Verify that the 120v power is working when the generator is on or the RV is plugged into shore power
o Check the oil level, water level in the radiator, water level in the windshield wipers, brake fluid level
o Verify that the RV has a full tank of gas
o Verify that the tire pressure is correct for all 6 tires and the spare (70-80psi)
o Check the tires for cracks, tread, and uneven wear
o Verify that the black and gray waste tanks are near empty
o Put 1 cup of gel detergent down the kitchen sink and toilet (keeps level sensors clean)
o Verify that there is fresh water in the holding tank
o Check all running lights, brake lights, turn signals, emergency lights
o Check headlight high beams and low beams
o Check that the horn is working
o Check that the radio is working
Here is another checklist I use when inspecting an RV prior to purchase:
Exterior:
Check the Manifold bolts! (…expensive to fix)
Inspect body for damage
Check all window seals
Check tread and date on tires. Look for cracking on sidewall and inside the tread
Test the waste tank sensor levels
Look underneath rig for rust, holes, etc
Look at rotors and brakes if possible
Go on roof and inspect seals, separation, soft spots
Look in engine compartment
Check battery voltage on chassis
Check battery voltage on house battery
Start engine and listen
Check battery voltages with alternator on (listen for solenoid click)
Check battery voltage with generator/shore on
Check headlights, running lights
Check turn signals, hazards
Check all exterior misc lights
Check horn
Inspect battery bank housing (need more support?)
Open/close slide-outs. Look at seals and topper
Open awning and look for rips
Check drainage valves
Test outdoor shower
Check tire pressure
Is there a spare tire? Tire iron?
Inspect all external storage compartments
Inspect generator
Inspect exterior entertainment system if applicable
Interior: Front
Check the dash for cool AC on all vent settings
Check the dash for heat on all vent settings
Check radio
Test door locking mechanism
Check power windows, wipers, water, and mirrors
Check backup camera
Open up doghouse (interior engine cover) and take a look/listen
Interior: House
Test side door locking mechanism
Check gauge control panel
Turn on/light LP (refrigerator, water heater, furnace)
Check that refrigerator operates on propane
Check cushions (open them) and under cab cushions for mold
Check all interior lights
Inspect converter panel
Turn on generator
Check microwave
Test TV and DVD
Test roof AC
Run roof AC and microwave at the same time with generator on
Check all electrical outlets
Check that refrigerator operates on generator/shore
Test furnace for heat, smell, air volume through each vent
Run kitchen sink and check under cabinet for leaks
Run bathroom sink and check under cabinet for leaks
Check for hot water from all valves
Inspect area under cabinets (open up/remove panel)
Look in all cabinets at ceiling for leaks
Test ceiling fans
Inspect all compartments
Check all windows and blinds for functionality
Check stove burners and oven
Check solar if applicable
Check inverter if applicable
Test gray/black tank sensors (ask to inspect when waste tanks are empty, but full tank of fresh water so I can test)
Take test ride on highway
Under load does AC/Heat still come out front vents?
Does the RV pull to one side when driving? When braking?
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
 > Where to begin
