RV.Net Open Roads Forum: How to avoid getting blown all over the road
Search only in Towing
Open Roads Forum  >  Towing
 > How to avoid getting blown all over the road
Page of 7
MyersAvionics
Iowa
Posted: 05/04/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
Curious on how I can avoid wind blowing the camper and my truck all over the place to the point of it being really annoying to drive and causing me to not even want to use it.
I have RAM 1500 with the 5.7 V8. It doesn't work too hard to pull my 29' toy hauler (7k lbs empty and ~8.5k with stuff loaded) at 65mph down the road. The problem comes in that even with slight side wind gusts I'm blown all over the place and I have to slow down to about 50mph to keep it drivable.
I have a BlueOx hitch with sway controls as well as the trailer friction sway control.
I have LT tires and after getting the weight distribution down pat, I have also installed airbags in the springs to keep the truck level. This helped, but I am still getting blown around the road.
I'm to the point of looking at a larger 2500 diesel RAM, or a full on drivable RV toyhauler, or just an RV that I would put a standard trail behind.
Before I go to these (expensive) extremes. Does anyone on here have any advice on something I could be missing?
Thank you,
valhalla360
No paticular place.
Posted: 05/04/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Take it by a weigh station fully loaded and get the numbers:
- Hooked up with WDH in place
- Hooked up without the WDH in place
- Truck by itself.
What's the payload ratings on the truck?
My best guess is you are light on the tongue weight but the numbers will tell.
No, it shouldn't be white knuckle drive if you are within the tucks limits and things are set up correctly.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BarneyS
S.E. Lower Michigan
Posted: 05/04/21 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Slow down to 60mph or less and put a Hensley hitch on the trailer.
Barney
Not towing now.
pianotuna
Regina, SK, Canada
Posted: 05/04/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I added air tabs. They helped with both noise and wind.
Oddly enough they improved gas mileage when there was a tail wind--but did nothing mileage wise for head or side winds.
Regards, Don
Sjm9911
New Jersey
Posted: 05/04/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
What year is the ram? And specs? The trailer is larger. What are you putting in the hauler section? As some said it might be taking weight off the toung.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Quartzsite, AZ
Posted: 05/04/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Responders can't say "slow down" too many times. Check the tongue weight.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
atreis
IN
Posted: 05/04/21 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
How heavy is the tongue? Tongue weight should be 11-15% of total trailer weight. If you don't have enough tongue weight when fully loaded, it'll be all over the road, and potentially very unsafe.
Being a toy hauler, too light of a tongue is also the most likely scenario.
2021 Four Winds 26B on Chevy 4500
time2roll
Posted: 05/04/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Does the front suspension rise or compress when you get all hooked up?
675w Solar pictures back up
JRscooby
Indepmo
Posted: 05/04/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
The tongue weight will make trailer less stable. But it would be unstable in calm too. Fact is the large profile vehicle will be affected by wind. A lot of the solution must happen between the drivers ears.
BurbMan
Noblesville, IN
Posted: 05/04/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Our 34' TT was 6900 lbs empty and 8500 lbs loaded, and it wasn't even a toy hauler....I suspect you are much heavier than you think you are. You may just need to move the toy(s) forward some in the garage to add some tongue weight.
Sounds like you're headed down a path that many on this forum, including myself, have been down before. The coil springs in the 1500 trucks aren't able to resist lateral forces like the leaf springs in HD trucks. The fact that you added air bags in the coils to level the truck not only aggravates the problem, but is a red flag that the WD hitch is not as "dialed in" as you think it is. LT tires help some but there's only so much you can do there.
Load the trailer and get it weighed, see if you can adjust loaded to improve performance. At the end of the day, I think a 2500 is in your future. BTW, you don't need a diesel, the 6.4 hemi will handle that weight just fine.
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Page of 7
