RV.Net Open Roads Forum: How to avoid getting blown all over the road
Search only in Towing
Open Roads Forum  >  Towing
 > How to avoid getting blown all over the road
Page of 7
BarneyS
S.E. Lower Michigan
Posted: 05/11/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that toy hauler trailers usually have the heaviest tongue weights when they are EMPTY of the toys. Adding them makes the tongue weight lighter because the toys are normally loaded behind the trailers axles and all the living quarters are mostly in front of the axles.
This gives them the heaviest tongue weights when they are not carrying toys back there.
Barney
Not towing now.
MyersAvionics
Iowa
Posted: 05/11/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
Keep in mind that toy hauler trailers usually have the heaviest tongue weights when they are EMPTY of the toys. Adding them makes the tongue weight lighter because the toys are normally loaded behind the trailers axles.
Barney
Duly noted and understood. The axles are set fairly far back for this reason as well. I still plan to weigh everything to get proper weight distribution.
BarneyS
S.E. Lower Michigan
Posted: 05/11/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I would set the WD to the heaviest tongue weight (no toys in your case) and call it good unless the handling of the vehicle deteriorated too much with the toys loaded. Of course, each person uses their rig differently and if you always tow with the toys loaded then you should probably set the WD for the loaded condition.[emoticon]
I would not try to compromise and set it for somewhere in the middle. Doing that will give you a "never right" situation which, in my opinion, is not good.
Barney
MyersAvionics
Iowa
Posted: 05/11/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Barney
We only use it when hauling bikes quite honestly. I may weigh it loaded and unloaded just out of curiosity sake.
I also just puked a bit and bought the ProPride hitch. Thought about the Equilizer, but figured if you're doing it, you might as well go all the way and be happy you did when you've got a 15hr trip ahead!
time2roll
Posted: 05/12/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Does the front suspension rise or compress when you get all hooked up?
I am still curious on the weight distribution effect on the front suspension.
675w Solar pictures back up
MyersAvionics
Iowa
Posted: 05/12/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
It looked pretty level even without the bags. I did notice the front end steering was a bit lighter without the bags though.
JRscooby
Indepmo
Posted: 05/12/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I watched a friend hook up, as we where discussing his handling issue. The front of TV came up when the tongue was lowered. Latched coupler, jacked back up to hook the bars. When lifted jack off ground, the front was still higher than before hooked up. When he aired up the bags, the TV was level. Made a bet the scale would tell him front was still light. Never measured, but bet both ends of TV where riding higher with trailer than without. When readjusted the bars, handling improved
MyersAvionics
Iowa
Posted: 05/12/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer hooked up our hitch when we purchased the camper. They very well may have not done it correctly. I never redid their install. I will be taking my time when I receive the ProPride next week when I install it to ensure it is done correctly.
2oldman
NM
Posted: 05/12/21 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
One nice thing about a Freightliner M2-106 MDT. Hardly notice wind at all.
Posted: 05/12/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Always at least one in the crowd....
2017 Heartland Torque T29
Page of 7
