RV.Net Open Roads Forum: How to avoid getting blown all over the road
Search only in Towing
Open Roads Forum  >  Towing
 > How to avoid getting blown all over the road
Page of 7
1320Fastback
Vista, Ca
Posted: 05/04/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I heard a rumor opening a window on each side of the trailer even just a little bit helps reduce the sway from cross winds or big rigs bow wave.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 05/04/21 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Your truck may pull it, but in my opinion, you don't have enough truck as to weight and wheelbase length to control that long of a trailer. The tail is wagging the dog.
I pull a 26' trailer with a 3/4 ton crew cab truck and eight ft bed. I have no wind problems at all. The tires are load range E.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
SDcampowneroperator
South Dakota
Posted: 05/04/21 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Air bags says it all to me, if you needed them to level the load,then your WDH is not set up right or your WD bars are not sized right. .
Measure unloaded front and rear bumper height adjust until near equal front to rear loaded truck and trailer , thats the Weight distibution job. Air bags tells me your WD bars are not set up right.
Done right your 1/2 ton can do the job fairly, LT tires and air bags ? might as well bought a 3/4 ton
* This post was edited 05/04/21 10:15pm by SDcampowneroperator *
pitch
NY
Posted: 05/05/21 06:59am Link  |  Quote  |  Print  |  Notify Moderator
What velocity winds are you talking? Even 80,000 lb semis get blown around by crosswinds. One trip westbound across Nebraska we saw two tractor trailers flipped by the wind and at one point I pulled over and stopped. If you are having trouble in 15 or 20 mph winds you have a problem, faster than that is normal.
Devo the dog
Moved out of crazy California
Posted: 05/05/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
atreis wrote:
How heavy is the tongue? Tongue weight should be 11-15% of total trailer weight. If you don't have enough tongue weight when fully loaded, it'll be all over the road, and potentially very unsafe.
Being a toy hauler, too light of a tongue is also the most likely scenario.
This is what I'd guess is the problem. Tongue weight is too light.
One of my trailers is a 34 ft bumper pull and I always check it with a tongue weight scale.
The dodge fan boys hate the dodge/ram dealerships. Now that I own a Fiat Qui-Qui, I understand why.
mkirsch
Rochester, NY
Posted: 05/05/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Toy haulers tend to have EXCESSIVE tongue weight, because the rear is left open for the garage, and all the "house" part of the trailer is ahead of the axles.
The fact that he needs airbags after the WDH is supposedly correctly adjusted strongly hints at this.
CarnationSailor
Carnation,WA
Posted: 05/05/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
Slow down to 60mph or less and put a Hensley hitch on the trailer.
Barney
X2 and verify proper setup of WDH.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
noteven
Turtle Island
Posted: 05/05/21 08:43am Link  |  Quote  |  Print  |  Notify Moderator
RV "bumper tow trailers" have their wheels in the pivot mount for a weather vane position, crossed with a teeter totter fulcrum.
Modern light duty trucks have fluffy suspensions.
I used a (bought used) ProPride hitch on a won ton single wheeler towing a heavy 32ft travel trailer (12500lbs). It stopped the wig wag from traffic bow waves and cross wind. It had certain other pains in the keester but it did not "sway". The rig went down the road like it was on rails.
memtb
Wyoming
Posted: 05/05/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
IMO .....the felt effects of a cross-wind are directly related to the square footage of the rv side wall area and the weight of the rv.
Again.....my opinion.......your unit is pretty light for it’s surface area. On a recent trip we had several hundred miles of high winds (Oklahoma well into Wyoming). We had no control issues, while others (semi’s and rv’s) appeared to be struggling. But, our 40’ 5th wheel weighs in at 20K. In a wind situation, heavy weight is your friend.....until the wind overcomes the rv weight! Then things get real ugly....real fast!
Many folks get uncomfortable movement with their towed unit when passing a tractor/trailer at highway speeds. We rarely feel the wind from a passing semi! Weight is your friend......until it’s not! [emoticon]
You simply have to determine your comfort level with your particular unit. In some situations.....that may mean parking her nose into the wind (like a boat on the water) until the wind subsides! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Posted: 05/05/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
This is an interesting theory that kinda makes sense. I'm going to try to remember to try it.
2017 Heartland Torque T29
Page of 7
