RV.Net Open Roads Forum: Towing: Is this hitch wrong?
Search only in Towing
Open Roads Forum  >  Towing
 > Is this hitch wrong?
l99057j
GA
Posted: 05/04/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a travel trailer last year. Knowing nothing about towing I used the setup as provided and haven't had any real issues. I've recently upgraded to a 3/4 ton truck and because it sits higher I expect to have to adjust my setup. Now that I'm reading up and learning more I'm starting to question some things about the setup we've been using.
Below is a photo of my hitch. My understanding is that when it has the added triangular support it is meant to be used in a drop configuration only. Am I right in saying that this should never have been installed in this configuration or is it acceptable?
Note: Moderator edit to fix picture link.
* This post was edited 05/05/21 07:10am by an administrator/moderator *
Seon
Lake Camanche, CA
Posted: 05/04/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see a picture.
Lynnmor
Red Lion
Posted: 05/04/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Should be fine.
Williams AZ area
Posted: 05/04/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Most can be dropped or raised and are advertised for both. What brand and model do you have?
Sjm9911
New Jersey
Posted: 05/04/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Who cares how you have been towing, you will need to turn the hitch over for the new truck. Set it up like the directions say. Remember to tighten it up good and check it before a long trip. Not knowing what your TT is, you may not need the wdh set that tight. I dont really need mine with the new truck but use it for the sway controll. I also had to ajust where the arms conected to the toung. But i also have a diffrent hitch. Good luck, do the measurements and set it up like you just got it.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
BarneyS
S.E. Lower Michigan
Posted: 05/05/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
You are incorrect in you thinking. The hitch can be used either way - up or down. Whoever told you you couldn't is mistaken.
Barney
Not towing now.
Ron3rd
Upland, CA USA
Posted: 05/05/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Properly adjusted it will work fine. It's Huskys version of the tried and true Equalizer
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Boomerweps
Hills of PA
Posted: 05/05/21 11:33am Link  |  Quote  |  Print  |  Notify Moderator
If it’s been towing right the way the WDH was adjusted on the previous truck, you just need to determine the correct height change to put the ball at its previous working height. Use the same number of tilting washers on the ball mount.
I had to flip mine up to raise the ball about 5” after underspringing my TT axle.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Posted: 05/05/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
You can use the stinger either way, no different.
That drop hitch should be sufficient for most stock height HD pickups.
2017 Heartland Torque T29
Ron3rd
Upland, CA USA
Posted: 05/05/21 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Correct. And preferably point it down to eliminate the possibility of contact with your tailgate. Your new truck is higher so you would probably want it that way anyway.
I towed with that style hitch for many years only in the Equalizer brand.
