RV.Net Open Roads Forum: Which of these 3 battery brands would you choose?
 > Which of these 3 battery brands would you choose?
edatlanta
Maplesville, AL Home Base
Posted: 05/05/21 03:53am Link  |  Quote  |  Print  |  Notify Moderator
Trojan T-105's here. My first set lasted 8 years and my second set is now 3 years old and going strong.
11 years full timer.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Posted: 05/05/21 05:10am Link  |  Quote  |  Print  |  Notify Moderator
I would (DID) got with DEKA but not AGM.... For the small amount of extra work that flooded wet cells require AGM's are just not worth the added cost.
StephJohn2010
Black Hills, South Dakota
Posted: 05/05/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
ArchHoagland wrote:
Where are you buying them? Online or local?
Buying them local, thru Rv repair shops.
John & Steph
2012 Fleetwood Discovery 40x (35,000 miles)
380 HP Cummins with an Allison Transmission - Freightliner Chassis
2015 Jeep Cherokee Limited Active Drive II
Quartzsite, AZ
Posted: 05/05/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
And an adequate solar system does that very well most days Mr. Wizard as you know.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ferndaleflyer
everywhere
Posted: 05/05/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I had used Interstate for many years until I discovered that Wal Mart and Interstate were made by the same company so I tried Wal Mart at 1/3 less cost and they are still doing fine 3 years later. I also have one in the Smart car and the Mercedes, replaced after 17years!
chuckftboy
Fleming Island, Florida
Posted: 05/05/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would go with Trojan as they are are very high quality battery and worth a few bucks more than other wet cells. The seller can say what ever they want but T 105's are wet cell not AGM's
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
time2roll
Posted: 05/05/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Why was Lifeline excluded?
675w Solar pictures back up
HHg in Austin
Austin, Texas
Posted: 05/06/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced my batteries with 6 of the Trojan T-105’s. Paid about $136.00 each at one of the local golf cart stores…..be sure to buy a battery strap to pull the old ones and replacing the new….sure makes the whole process easier. They are heavy…. All the research I did….pointed to the Trojan as the best. Also agree with earlier post….they are wet-cell.
HHg in Austin
2013 Tiffin Phaeton 40-QBH
2018 Chevrolet Tahoe Toad
ArchHoagland
Clovis, CA, USA
Posted: 05/06/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
HHG in Austin said:
".be sure to buy a battery strap to pull the old ones and replacing the new….sure makes the whole process easier. They are heavy…."
Amen to that!
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
DamBeaver
California
Posted: 05/08/21 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Skip all of these options and get the new Fullriver EGL series AGM. https://www.fullriverbattery.com/product/egl200-6/
This battery is brand new, has the longest warranty, will do twice the cycles, and is safe to discharge 80%
This is an incredible battery, get these or update to Lithium.
Source: I work for a battery distributor
