RV.Net Open Roads Forum: Class A Motorhomes: Dead batteries
Poppy2003
Lake Anna, winter storage.
Posted: 05/05/21 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
winter stored RV for 6 months, no shore power, now batteries are dead, can I jump start with my car battery?, my Generator also not starting, thank you.
garym114
Bluff Dale, Texas
Posted: 05/05/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
probably not, use a 110v battery charger. This may not work because the batteries sat a long time with no charge, totally dead, may have to be replaced.
Next time move the negative cable from all batteries.
see my signature
navigator2346
Wa and points South
Posted: 05/05/21 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yes to the jump start. After you get the coach running, you might be able to start the generator after a few minutes. It would be best to get a stand alone battery charger and make an attempt to charge the batteries instead of trying to use te generator and on board charger. Your batteries could be toast
ArchHoagland
Clovis, CA, USA
Posted: 05/05/21 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'd put the jumper cables on and let it charge the starting battery for about 20 to 30 minutes before I try to start it.
Friend of mine just had the exact situation at his storage location, we let the car charge the battery and got it going.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
valhalla360
No paticular place.
Posted: 05/06/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Are they completely dead or just weak (turns over real slow)?
Also, what is the motor? A gas V10 probably. A big diesel...less likely.
If you have access to shore power, better to get a charger on it
If you do jump start, make sure the car engine is left running, so you don't kill the car battery. Also, if you get the MH engine running, operate under the assumption the battery won't restart it, so don't shut it off unless it's somewhere you can leave it.
Removing the battery terminal (or putting in a disconnect switch) is a good idea but doesn't help you now.
If you are lucky, the battery will be OK but plan on replacement.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
jdc1
Rescue, Ca
Posted: 05/06/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
If it's a diesel, you'll need more than a car to jump start it.
Poppy2003
Posted: 05/06/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
no its gas, ford v10, 2003 Itasca sunova 30b, thanks,
Poppy2003
Posted: 05/06/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
see my signature
Thanks, I'm a new RVer, bought it in last october and winterized and stored, shop never told me to disconnect - pole, I guess you live and learn, batteries are 4 years old. Planned a trip to all the National Parks this July on.
Poppy2003
Posted: 05/06/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, will try that first, if not have to change all the batteries, keep it AGM, as Lithium is very expensive for a retired old man.
phillyg
SWFL
Posted: 05/06/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Don't give up on your batteries. I've successfully brought mine back from near dead twice now. Since then, I keep them up with a small solar panel while in storage.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
