RV.Net Open Roads Forum: Truck Campers: Recommendations for a noob...
 > Recommendations for a noob...
RickW
Sacramento CA
Posted: 05/06/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Have you accounted for steps to get into the camper once loaded?
Bring extra ratchet straps in case the tiedowns/turnbuckles don't work out on the trip home.
Know what tire pressure you need when carrying the camper. Know the height of your loaded rig.
As noted above, planning to camp the first night in the dealer lot can be a benefit to try out refer, stove, heater, plumbing, review notes, etc. Will dealer fill the propane tank?
Research truck camper loading checklists now and plan to use one every time.
Enjoy.
Rick
04 GMC 1500 4X4X4
04 Sunlite SB
Posted: 05/06/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Stall mat or rubber bed mat, necessity almost on a steel bed.
Presume your flatbed has continuous tie down rails or similar so you can anchor the camper as needed?
Some sort of spring loaded device on tie downs? Maybe not 100% necessary for a short trip home, but you may over stress the tie downs on the camper if you lash it down hard.
Does the camper have dually extensions on the front jacks? Are they wide enough to clear your flatbed?
Is the camper longer than the flatbed or do you have rear swing out dually jack mounts for the rear as well on the camper?
Do you have a way to block the front of the camper, aft, if cannot load it all the way forward (note, you were not specific about the dimensions or style of your flatbed at all)?
Will the camper clear the truck roof? (Again, don't know anything about the truck bed)
Will the camper get up high enough to get onto the flatbed? Got blocks and/or a way to shore the camper up if you need to block it up?
Light plug extension or plans for hooking up lights?
Since you also don't mention the model or height of camper and model of truck, know that you could be approaching 13' tall with your combo.
That's about it for the minimum to get it on your truck and down the road safely.
2017 Heartland Torque T29
mt-ed
Montaha
Posted: 05/06/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
WOW!!!! You all have really offered so much valuable information. As advised, I was planning to video the "walk through". Regrettably, I cannot stay onsite for even a night. My trip alone will be 10 hrs. each way, and I cannot stay away that long as I have livestock and other responsibilities I must get back to, and I'm concerned about the minimum time I'll have to take off.
I will apply your ideas, they were exactly what I was hoping for!!!
Thanks so much again....
Posted: 05/06/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck!
So what kinda camper is it?
mt-ed
Montaha
Posted: 05/06/21 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
The truck is a Ford F550 flatbed and the camper is an Eagle Cap 1160.
Posted: 05/06/21 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, nice!!
Camper_Jeff_&_Kelli
Seattle
Posted: 05/06/21 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
You bought the right truck for the camper. The first thing lots of folks get wrong. I've used Torquelift, chains, and turn buckles for as long as I've had my setup. One thing I did do was get stainless steel chain connectors. I bought BIG turnbuckles and they're aluminum. Get a good quality blue drinking water hose so you don't get so much plastic taste in your water connection. It's a Ford so getting power to the TC through your pigtail is available. My truck a cube relay was required to be installed next to the fuse panel under the hood. research how yours works. Also, one the best things to do is get a smart solenoid and connect a 4 gauge from your alternator to your TC batteries for much better charging. I would get at least a 300 watt solar system installed with an MPPT controller. You can go from there how you want with batteries and other improvements. A 1000 watt pure sine wave inverter is a great thing to have for running your 120 volt appliances. Paper Plates, plastic ware, baby wipes, a couple GOOD camp chairs, ziploc bags. You can build a pretty good list. I kind of concentrated on things for the truck and camper. For other stuff, just get what you like at home and see how it fits in for your travel style and before long, you'll have a good idea of what works. Best wishes on your soon to be travels...
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
