RV.Net Open Roads Forum: Truck Campers: Electrical question
 > Electrical question
tuna fisher
joshua tree ,ca.
Posted: 05/06/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
My utility trailer wires to the right side were dragging when I got to my camp area, put them back together but my right turn signals on the trailer and camper are not working, just the right side. All other lights work including the truck right TS. Checked all fuses and bulbs. It's just the Camper and trailer right turn signal that don't work. Where should I look to fix the problem.
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!">
Reality Check
North Bend
Posted: 05/06/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I know you said that you checked the fuses, but did you check the trailer turn fuse? Most of our trucks have separate blocks. Since it's on the camper and the trailer, but not the truck, I can't think of any other obvious scenario.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
enblethen
Moses Lake, WA
Posted: 05/06/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Check owner's manual for location of trailer connector fuses, if equipped in your make and model.
Look at this site. Slide down to the under-hood fuse block diagram.
Fuse block
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CA Traveler
The Western States
Posted: 05/06/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Dragging wires could mean cut or separated wires somewhere. Run a temp wire from the truck to the trailer light to confirm. And just because the truck light works that doesn't mean the connector wire is working.
2014 Grand Cherokee Overland
Bob
tuna fisher
joshua tree ,ca.
Posted: 05/07/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Thank you gentleman problem solved, was the fuse in the under hood power station. Was to easy for me to figure out.
enblethen
Moses Lake, WA
Posted: 05/07/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Easy things can be the hardest to find!
