RV.Net Open Roads Forum: Can1500w inverter or Honda 2k gen work 900w Microwave
 > Can1500w inverter or Honda 2k gen work 900w Microwave
DAS26miles
SoCal
Posted: 05/09/21 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
My brother has a High Point microwave 900w with 1350w operating. He says the inverter won't run the microwave even on a totally isolated circuit. Starts then stops. Now he is worried that his Hoinda 2200i generator may not have enough power either. He has major trips coming up and wants to get the microwave working off shore power.
* This post was edited 05/10/21 12:18am by DAS26miles *
MrWizard
Traveling
Posted: 05/10/21 12:37am Link  |  Quote  |  Print  |  Notify Moderator
How many batteries does Brother have connected to the inverter w/o and what size wire, mucho battery capacity is king when it comes to this situation,with Big Thick Cables, for the high amps
I consider a 1500w inverter not large enough for a 1300x load, doesn't allow for sufficient overhead for inverter conversion loss 15% need 1495watts into the inverter from the batteries, and that doses not include startup surge spike
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 05/10/21 03:18am Link  |  Quote  |  Print  |  Notify Moderator
The short answer is yes. I constantly run my microwave with one EU2000i generator. Of course, it depends on what else is running. Maybe the reason his inverter won't power the microwave is that things are running that he has either forgot about or doesn't realize they are powered by the inverter?
2021 F-350 Platinum 4X4 PSD SRW 2016 Montana 3950FL (2) Honda EU2000i's
...and a few (twenty-some, but other than my wife, no one is counting) antique Allis Chalmers tractors
BobsYourUncle
Calgary Alberta Canada
Posted: 05/10/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I run my micro on my Honda 2000. You can hear the sound of it slow initially on startup while the genny ramps up speed to keep up with the load, but it works fine.
I run it in Econo mode so it doesnt always rev so high.
I don't know how many watts mine is, never checked. It came with the TT.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
DAS26miles
SoCal
Posted: 05/10/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
My brother says he has 2awg cable going from inverter to 2 BB Lithium batteries. He is calling GoPower today as he bought their inverter with their recommendation. He says all testing has been done directly with isolated circuits soley the microwave. If he can get the inverter to handle the load, then he can alway use it that way instead of using the microwave.
I will be camping with him tomorrow and will bring all my test equipment like clamp-on ammeter, Kill-a-watt and short power cored with exposed wiring for clamp-on use.
ktmrfs
Portland, Oregon
Posted: 05/10/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
genny yes.
inverter depends
1) what size battery cables and how long the run from battery(s) to inverter
2) what size and number of batteries
3) battery state of charge.
4) inverter max continous rated VA
2011 Keystone Outback 295RE
Sandia Man
Rio Rancho, NM
Posted: 05/10/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Whether the inverter can power your brother's microwave is one matter, the toll to 2 batteries for just a few minutes of microwave use will take a significant bite out of the onboard 12 volt reserves. This will eventually lead to powering up the genny earlier and longer to replenish consumed amphours, our inverter could power up our microwave but I always would run the genny since it would literally zap our 2 battery setup.
We have plenty of solar which helps, inevitably when using high amperage items (microwave, blow dryer, curling irons, coffee makers, blenders, etc.) on just a dual battery bank the generator ends up being used more than necessary. We have an Iota IQ4 smart converter that quickly restores our batteries during bulk charging, having a remote start genny (Onan/Champion 3100) makes it easy for us to use high amp items at our convenience.
DAS26miles
SoCal
Posted: 05/10/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
MY brother travels alone and only uses the microwave to cook or defrost for s hort time. He only drains the 200amp bank about 50amps max and he has 400watts of solar which usually recharges the batteries.
Again, I will see him tomorrow at the campground and give it a full checkout. I think his microwave has his inverte overloaded and cutting out because of it. He called GoPower today but hasn't returned my call yet.
Posted: 05/10/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
It may depend on other thigns.
My Inverter was 2000 watts not sure of the Dometic/LG microwave. CDMW12
Ok now sure
Power 1100 watts
Rated consumption 1500 Watts
My 2000 watt inverter needed FULL batteries to Well make a less than 1000 watt cup of coffee. .But it ran the microwave fairly.
You have a 900 watt or about 82% (81 and change)
81 (and change) Percent of 1500 is 1227 and change
That is close But the Honda should take it provided, once againg the batteries are FULL or the converter is OFF.
DarkSkySeeker
Freestone, California
Posted: 05/10/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
I've been able to run mine while the Honda 2k powers it. In fact, I had to tell the DW to let the generator run for a minute before slapping the MW on. I had to explain to her the generator needs a minute to warm up. She literally pressed the ON button just as the generator fired.
I have never tried an inverter.
There is something special about camping in an RV.
