RV.Net Open Roads Forum: Towing: First Long Road Trip
Search only in Towing
Open Roads Forum  >  Towing
 > First Long Road Trip
valhalla360
No paticular place.
Posted: 05/11/21 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Lusson wrote:
Trailer Axle weight is yes 7700lbs from the scale. According to my car it can tow 9400lbs but has a GCVW of 15,900 rating as well.
As far as trips we only go camping about an hour away normally and plan to take one long trip a year. This year going from Iowa to Mount Rushmore.
The scale fully loaded with gear and people said I was at 14,500.
Something still off with the weight data as the trailer axle weights will change with the adjustments to the WDH but it sounds like you are probably within ratings.
Unless there is an existing issue, why mess with a 2nd sway control bar. If you really are at 15% hitch weight, sway isn't very likely.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Lusson
Iowa
Posted: 05/12/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Per the sway bar manufacturer of multiple companies if you have a camper heavier than 6000lbs or longer than 26' they recommend a second one. Granted every time I've taken out my camper on the road its been 20mph or greater. figure with having a 36' camper a second one to help out is cheap $49 insurance. Yes one more thing to hook up and what not but yes sway is an issue but hoping with the change in my WDH and Tires and the second sway will just make it that much better to tow.
But every time right now if I go above 60mph it does get a little crazy but also my front end was light. Going on a short camping trip this weekend only 25 miles away. So see how she handles this next trip and will report the results on everything I changed from last time out.
Lusson
Iowa
Posted: 05/12/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Ok I will try to make it more clear here.
Nothing on the Expedition
Front Axle 3340lbs with 36" Wheel Well Spacing
Rear Axle 3480 with 36" Wheel Well Spacing
With WDH on Link #3
Front Axle 3220lbs with 36" Wheel Well Spacing
Rear Axle 4540lbs with 33" Wheel Well Spacing
Trailer Weight on Both Axles 7520lbs
With WDH on Link #4
Rear Axle 4380lbs with 34 3/4" Wheel Well Spacing
Trailer Weight on Both Axles 7740lbs
So thinking I have my front axle back to normal and not light which I thought I could feel when hit a bump with steering getting light. Also again putting on Load Range E tires to help with SUV sway and adding a extra sway bar with having such a long and heavy trailer.
Hope that clears items up and these were with everything loaded as going camping and people. GCVW for mine is 15,460 and figure my hitch weight is around 1000lbs. so that puts it right at 15%.
Again most camping is going to be 50 miles at most with one trip a year being about 1000 miles round trip. Handles good now until I get up around 65-70mph this was on WDH Link #3 and again its been 20mph winds each time so figure just keep her in the 60-65mph range when driving and sway should be gone with all other changes should see how things go for this weekend's short camping drive of 25 miles. First time driving on Link #4 with Tires and Extra Sway Bar.
Posted: 05/12/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
If I had a trailer that didn’t “handle right” at 60 or65 or 70 mph, I’d sell it, or drop it off in downtown seattle for the homeless to live In and report it stolen!
2017 Heartland Torque T29
packpe89
NC
Posted: 05/19/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Couple things, the XL is not a 3/4 ton, that implies same frame as an F-250. It's an F-150 frame with the towing package. You are certainly border line on weight, but length would be a bigger concern. That is allot of surface area. Fortunately you are taking a fairly flat trip and to a beautiful location. Just hope it's not windy. If planning to take many more of these trips, I would certainly consider F-250/2500 or if more seats are needed, even a 3/4 or 1 ton van.
Good Luck
APT
SE Michigan
Posted: 05/21/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
If you to get to a scale again, can you get the weights without any WD spring bars? That will provide data to calculate actual TW.
Something seems off on the unhitched weights, unless that is with the whole family onboard and full of fuel.
My estimates are your TW is around 1150 pounds and TT weighs 8850 pounds loaded. I also believe you are exceeding the receiver, rear axle, and GVWR of the Expy.
For the first question: 4 links is as close as you should try to get as you have 100% font axle weight restored.
2017 Subaru Outback 3.6R
Boomerweps
Hills of PA
Posted: 05/21/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
With WDH on Link #3
With WDH on Link #4
I look at a a WDH to be like a handle that pushes down on the whole TV on all four wheels. I think returning the front weight is great but not enough. Because the extra rear weight pushing the TV down in the rear unloads the front relative to the rear. So pushing a couple hundred pounds to the front wheels works better for me in the steering balance equation.
Shorter answer: I’d try five links before settling down.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
LanceRKeys
Amarillo, TX
Posted: 05/21/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I’d just bring the tools to adjust your WDH with you and adjust on the side of the road. You can have your weights “perfect” and the trailer is all over the place, you can also have your weights way off and it pull just fine. If your driving and it doesn’t feel right, put an extra link on, or tighten your sway control a bit.
Posted: 05/21/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Fortunately, you're mistaken. But in the "steering balance equation", whatever that is, how much difference does a couple hundred lbs above or below the unloaded FA weight make?
mr_andyj
Georgia
Posted: 05/22/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Difference on a 1/2 ton to a 3/4 ton truck (suv)=
usually is the same frame with a few extra pieces welded to the frame to make it stronger, usually turning what is called the C-channel frame shape and closing it into a tube in key areas,
and
heavier rear axle and differential.
and
either extra leaf spring or just a bigger set of leaf springs
or
if rear coil springs, then a heavier set of springs to take more weight.
other things include bigger brake rotors/calipers and other upgrades that will not affect towing a trailer forward so I will not mention as these are not the discussion.
Sounds like you did your homework and are within the limits of the vehicle. You might find that 60 mph is almost as fast as you want to tow, for safety and for mpg's. Leave 5 mins early if you are in a hurry, right?
Think of the WD hitch setup as a triangle that includes Tv front axle, the ball hitch and the trailer axle ( not need to include other axles here).
The bottom left corner is the TV front axle, the bottom right is the trailer axle (s) and the top corner is the ball.
With no WDH there is a connection from bottom right to top, and bottom left to top, but nothing from the bottom corner to bottom corner.
With WDH the bottom corners are also attached.
Stay with me...
If you pull the bottom corners together then the forces tend to pull those "legs" towards each other and push the top corner (the ball) up.
IF those legs have extra axles on them, like the rear axle on a TV, then those axles would eventually come off the ground, but in this case they are just unweighted a little.
This is a good way to visualize what the WDH does.
