RV.Net Open Roads Forum: i-5 san diego thru LA rest stops?
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > i-5 san diego thru LA rest stops?
Whangler
Northern CA
Posted: 05/10/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
There are no cal trans rest areas on I-5 in so-cal. My truck and trailer combined is 50' long. Coming from yuma, az to sf bay area. I've passed this way many times but would always just blow non-stop through I-5 from San Diego to Santa Clarita where I'd stop for gas. Nowadays, I need to stop to rest more often. Any recommendations for relatively stress free places to stop along this route?
DarkSkySeeker
Freestone, California
Posted: 05/10/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I don't think there are any. I've driven that stretch a dozen times or so. I don't think you'll find any rest stops until you're past the Grapevine.
There is something special about camping in an RV.
CA Traveler
The Western States
Posted: 05/10/21 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Gas station or truck stop but I wouldn't stop in the LA area.
You're taking the worst possible route IMHO, suggest
1. 405
2. 15, 210
3. 86, 10, 210 or 215, 15 to below
4. 15, 395, 58, 99 46, 5 or over to Palmdale to 58
5. AZ 95 to Parker, CA 95, 40, 58 and above - Best route
2014 Grand Cherokee Overland
Bob
EYEMLOST
See Above
Posted: 05/10/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
May I suggest taking an inland route North, then crossing over to the I5?
Many options there.
Otherwise; there isn't much from downtown San Diego to Whittier along the I5 corridor.
EYEMLOST
See Above
Posted: 05/10/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
1. 405
2. 15, 210
I concur on all points.
jdc1
Rescue, Ca
Posted: 05/10/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
50'? I pull over into warehouse areas when I head to Phoenix. Just rest where the truckers rest, away from the fueling station and freeway noise. Up by lake Piru, on the 5, there is a museum that closes at 5pm. It's always empty and quiet.
FrankoToo
New Braunfels, TX
Posted: 05/10/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
There's a rest area northbound I5 in between Oceanside (north San Diego) and San Clemente. Next one I believe isn't until the Grape Vine as you drop down into the central valley. Once you get out of the LA area though, lot's of truck stops with plenty of space to take a break.
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
opnspaces
San Diego Ca
Posted: 05/10/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
FrankToo has it, those two are still open. During daylight hours you can also add in the Pyramid Lake visitor center, You'll see the Octagonal building on the west side of the freeway. The bathrooms are usually clean and you can walk around and look at the displays of how the water gets from northern to southern California. When my kids were younger we stopped there whether they needed the bathroom or not.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
profdant139
Posted: 05/10/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
The absence of rest stops in Southern California is just shameful. What are most people supposed to do?
Fortunately, we RVers have another option -- just pull off the freeway into a wide open shopping center parking lot and use the facilities in your own RV -- much cleaner and safer than using a public restroom.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
profdant139
Posted: 05/10/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I should add that the absence of rest stops was a big factor in our decision to get a FloJet macerator for home use. We are now much more likely to use the facilities in our trailer while on the last leg of a trip, because we can easily clean out the black tank at home.
