RV.Net Open Roads Forum: General RVing Issues: Running Inverter Generator Safely From Pickup
 > Running Inverter Generator Safely From Pickup
KeithF40
Long Island, NY
Posted: 05/12/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
First off I think I am definitely going to get a second (and maybe third) CO alarm in addition to the one that is built into my trailer.
pitch wrote:
I run our Hondas regularly from the bed of my truck. I drop the tail gate start the generators,spin them so the exhaust faces out. The tonneau cover stays in place one fold open, depending on expected weather,if rain is expected I leave it flat. I have a trifold. I have set my extended run tank on top of the cover.
This is for overnites only so I normally do not unhook the trailer. Once set up in our spot the generators sit on a piece of plywood on the ground.
By spin them out do you mean blowing perpendicular to the truck as in not towards the hitch and not towards the cab?.
Say wut?
Generator won't melt if it gets wet.
Why on earth would you direct the exhaust back into the enclosed truck bed making the bed all stinky and hot? Do you think it's going to trap the exhaust and keep it from getting out?
Point generator exhaust away from the truck bed and if you smell exhaust in the camper, it's not working, get a longer extension cord.
I felt this wasn't a good idea but read about others doing this so just wanted to ask. In regards to the rain I have read about people using it exposed to the rain and others covering it up so not sure what the exact protocol is.
pitch
NY
Posted: 05/13/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Say wut?
Yes face too face
ktmrfs
Portland, Oregon
Posted: 05/13/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
mr_andyj wrote:
you are right, CO is about the same as air. That is a myth...
We had a situation where a guy in a tent got CO poisoning but the people walking around were unaffected. I guess that supported the myth...
If CO floats then that is worse as it can float into your windows.
CO2 is harmless, you exhale it and breath it in. The mask-breathers are breathing it constantly inside their gross mask.
CO2 is harmless in "normal" concentrations. But In high concentrations can also lead to oxygen starvation and death. It is indeed rare, but can happen with inadequate ventilation when used a MIG or TIG welder running CO2 with inadequate ventilation.
2011 Keystone Outback 295RE
gtnsmlr
On the road
Posted: 05/13/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 05/13/21 05:32pm by gtnsmlr *
The older we get, the faster we go
gtnsmlr
On the road
Posted: 05/13/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I built a secure and weatherproof box that's bolted to the bed, it's properly ducted and has run fine in all weather for 700 plus
* This post was last edited 05/13/21 05:39pm by gtnsmlr *   View edit history
dieseltruckdriver
Black Hills of SD
Posted: 05/13/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
ol Bombero-JC wrote:
Maybe "mr_andyj" is thinking of propane?
[emoticon]
This is honestly an easy mistake to make. To make matters worse, RV manufacturers use a combination CO/propane detector, and since it involves propane, it must be near the floor.
I would always advise an additional CO detector. $30 bucks isn't much to be safe.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
miltvill
Ft. Lauderdale FL
Posted: 05/13/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I think running a generator in your truck bed would be as safe as running the built in generator in a RV that is located under the front bed. What is the difference?
Just make sure the generator gets fresh air or it will not run correctly.
I had a rat problem in my shed. So I ran my Honda EU2000 generator in my shed with the door and windows closed. After a while the generator ran out of fresh air and quit. Took of care of my rat problem.
* This post was edited 05/15/21 03:12pm by miltvill *
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
Posted: 05/13/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
^Now that’s thinking!
To the OP, don’t make this difficult.
Start genny, don’t point exhaust at anything that may melt or catch fire. If you want to direct the exhaust back under your tonneau cover (although idk how this would seem like a solid idea), do so. As long as you pay attention to the first sentence.
Rain, snow, wind, sun, generators seem to run just fine.
Common sense. Every construction site with a generator, it’s likely outside.
At home, my backup genny only comes out when the power is out and generally it’s raining or snowing.
2017 Heartland Torque T29
mr_andyj
Georgia
Posted: 05/13/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
OK, so get a CO monitor and no welding in the RV!
capacitor
California
Posted: 05/13/21 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, so put the gen on the tailgate with exhaust facing the drivers side. If it is raining have a piece of plywood on top and call it good.
