RV.Net Open Roads Forum: Quad Bike mounted to ladder?
 > Quad Bike mounted to ladder?
TBammer
Mid-Michigan
Posted: 05/11/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
We purchased a Vier Bike as something DW and I can do together. The bike cannot go into the back of the truck. I am thinking of rigging a block and tackle to raise it up and strap it to the ladder spiderman style (4 wheels against trailer back wall). The ladder is rated to 300# and I think the weight of the bike is 125. Any CONSTRUCTIVE ideas out there, pro and con?
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
schlep1967
Harrisburg, PA
Posted: 05/11/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I probably wouldn't do it without calling Arctic Fox and asking their opinion. If I were going to try it, I would make sure it is strapped so there will be no movement/bouncing around. And better would be if you could get a hitch type of carrier attached to the frame under it to support most of the weight.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
DarkSkySeeker
Freestone, California
Posted: 05/11/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
A while back a contributor here wrote, "never use the ladder for anything other than climbing to the roof". I've used that as gospel since then.
* This post was edited 05/11/21 08:29am by DarkSkySeeker *
There is something special about camping in an RV.
enblethen
Moses Lake, WA
Posted: 05/11/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I would think about a front hitch and no use the ladder.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
FWC
The Wilderness
Posted: 05/11/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
The 300lb rating for the ladder is most likely a 'static' rating - ie a big fat guy can climb the ladder with the camper parked. Although I would be doubtful that the manufacturer did any sort of calculations and just had Bubba go climb it to test it. What you are suggesting would be a dynamic load - a load that is there while the camper is in motion. With it hanging way off the back, if you hit a dip or speed bump a little too fast, the effective load could easily exceed 300lbs due to the g-forces and leave your ladder and bike lying in the road.
I wouldn't do it.
CA Traveler
The Western States
Posted: 05/11/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Ladders are not designed for dynamic weight bouncing and vibrating down the road. In addition you have a 4' high bike that will increase torque applied to the ladder.
Leave the bike at home.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 05/11/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
And if it comes off resulting in property damage or injury will your insurance cover it?
TurnThePage
North ID
Posted: 05/11/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I watch RV reviews on youtube. That ladder flexes every time someone climbs up/down. I think you'd be asking for trouble. At the least, water proof seals could break down where the ladder is attached to the RV. Don't those things come with pretty hefty rear cargo hitches? I think I'd rather fab something to that.
2015 Ram 1500
2004 Pioneer 18T6
CA Traveler
The Western States
Posted: 05/11/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
How about a small trailer or swivel wheel dolly?
mr_andyj
Georgia
Posted: 05/11/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure what a quad bike/Vier Bike is.
125 lbs is not going to destroy the ladder.
Your camper has springs and shocks, so the "bouncing" will not be so harsh, no more than you climbing on the ladder and bouncing a little.
Is this a battery bike? Take the battery out to lower the weight.
Can you secure the bike such that the tires are touching the bumper so there is another point of contact?
You will find that forum people panic quite easily. Ask and they will tell you to never even climb on the ladder as it could break.
I have seen many ladders with multiple bikes and other junk on them.
Always a potential that the ladder breaks, but Im doubtful that the ladder will fall off on a trip all at once.
You should be fine.
