RV.Net Open Roads Forum: Towing: Thoughts on WD hitch need
Search only in Towing
Open Roads Forum  >  Towing
 > Thoughts on WD hitch need
Reisender
NA
Posted: 05/11/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Mike134 wrote:
I have to chuckle at the weight police. I've been on the forum a few years and all you read is you need a bigger truck, blah, blah, blah. The OP has a 1-TON DUALLY ONLY towing a 10,000 trailer and suddenly it's not enough truck?
You guys crack me up.
Safe travels, hitch up and never look back at the forum.
So now I’m curious. What is the weight rating of new dually receiver. My old dually had two rating. One with and one without.
BarneyS
S.E. Lower Michigan
Posted: 05/11/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Who said he needed a bigger truck? I noticed a lot of questions about the receiver on the truck but not the "blah, blah, blah" that you talk about.[emoticon]
Barney
Not towing now.
Mike134
Elgin, IL
Posted: 05/11/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
Post number 5 and post #2 stated that truck would be "manhandled" by the trailer
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
loydt
Cornelius, NC, USA
Posted: 05/11/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the delay. I can tell you that it's a class V hitch with a tougue weight rating of 1800 lbs per ram website. The truck itself has a maximum trailer tow rating of over 30k pounds.
2021 Jayco Seismic 4212 (on order)
2021 Jayco White Hawk 32BH
2018 Ram 3500 DRW 4x4 CC Cummins/Aisin Laramie Longhorn
Reisender
NA
Posted: 05/11/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the comeback.
thomasmnile
Lake Mary, FL
Posted: 05/11/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Wonder what the Ram owner's manual recommends. Haven't seen a vehicle manual that doesn't address towing if it's capable of towing.
blt2ski
Kirkland, Wa
Posted: 05/11/21 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Mike,
I've had an 8500 lb trailer behind my 12k empty dump flat bed, with a 188" wb, 8k front axle, and 16.5k Ra manhandle the truck! ALL because it was loaded incorrectly with no hitch weight!
To others and OP,
To adds few other things, 1500 lbs of hw with a typical grawr of 8500, will remove around 200-300 lbs off the fa. Not a big deal. BUT a SW rig with a 6000-7000 grawr loses 309-400 lbs. This from experience is where handling issues from too little wt on the fa occur. Reality, no a WD is not needed for OPs truck.
Also with that said. From experience towing a box with a SW 3500 crew cab with typical 170" wb with 8' bed. I can tow said box loaded correctly with my fingers with no WD. BUT with a WD attached, I notice less side to side rocking of trailer in 20-30 mph side winds. LESS yet with a Reese dual cam. I would suspect less yet with a Hensley. No experience with a Hensley.
I have also been move half a lane to driver's side with a 60-80 mph gusts on I205 going north across Columbia River from Portland. Everything moved as a unit with the dual cam. No side to side uncontrolled fish tail sway.
With above said, I too will add use a WD anti sway system. ALSO make sure your trailer fully loaded can and does pull straight at any speed you are comfortable at. Be that 70 mph, or 60-65 is my general towing max. NOW add the bars for added insurance safety. If the trailer fishtail sways before adding bars. You've attempted to fix an injury with a band aid, when you need a tourniquet! If the bars fail, your screwed. Yes, I've had bars literally fall off, did not notice before driving over one mountain pass with some snow and ice in the roadway. Lightly snowing to boot!
My 02 on ALL the above
Marty
Check RV.Net Blogs at: blog.rv.net
Posted: 05/11/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
1800lbs weight dist or weight bearing, 20klbs max trailer weight.
2017 Heartland Torque T29
Posted: 05/11/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
No need to wonder, google will tell ya in about 30 seconds.
Posted: 05/11/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Only rated for 20k bumper pull trailers. Be tough to tow much more than that without tanking the back of the truck and being WAY heavy on tongue weight.
