RV.Net Open Roads Forum: Towing: Thoughts on WD hitch need
Search only in Towing
Open Roads Forum  >  Towing
 > Thoughts on WD hitch need
Mike134
Elgin, IL
Posted: 05/14/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
Mike134 wrote:
If you properly load the trailer you won't need sway control because a "PROPERLY" loaded trailer won't sway.
What's "proper?" Do you have a formula, or a method? Every trailer is different. Some will not even wiggle with 5% tongue weight. Some will whip all over the road with 20%.
"Move stuff around until the trailer stops swaying" doesn't seem like a very practical way to go about it.
I might just be dumb and lucky.........never ever seen a trailer sway at 20% tongue weight but then again how would I have any way of knowing? How did you find out?
I just load the tongue heavy and go. I was curious with my latest trailer and bought a sherline scale it comes in at 17% no sway so "if it anin't broke don't mess with it"
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
loydt
Cornelius, NC, USA
Posted: 05/14/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. I have all the info I need.
2021 Jayco Seismic 4212 (on order)
2021 Jayco White Hawk 32BH
2018 Ram 3500 DRW 4x4 CC Cummins/Aisin Laramie Longhorn
